Forks What about these Forks
   / What about these Forks #1
DRL
   / What about these Forks #2
DRL,
I had considered one of these but bought the 42" forks from Everything Attachments that advertises here along with a tooth bar from them.
What sold me was how easy it is to adjust the width and that you can see past the back of them. But the main thing is they are light weight. The ones you are looking at on ebay weigh over 375 pounds, about 150 more than the ones I bought. The 3400 is already on the light side of what it will handle and to give up another 150 pounds just didn't make since.
Scott
Thanks for the reply. There Bradco forks were the other ones I was looking at, but they are $160 more. I was wondering if the ebay add says "more than 375#" to make it sound more heavy duty and that is really shipping weight?
DRL
   / What about these Forks #4
I will add another vote for the light-weight 42" forks from Everything Attachments. Got mine in 07 and am really pleased with them. They will easily handle anything a 1600 lb loader can lift while providing more usagle lift than those heavier forks.
Thanks John, I grew up in middle Tenn. Lots of fond memories. I'll sleep on it this weekend and order something.
DRL
   / What about these Forks #6
Um.. your loader on the L3400 is rated for 1600 lbs?
Is it the LA463? Thats whats on mine.. and its rated for only 1142 lbs at the pivot pin and 1014 in the center of the bucket. no big deal, but I would think that the lighter the forks the better, as long as they can hold up to the stress.
Just food for thought..
James K0UA
Koua, yes it is theLA463. You had me questioning my memory (or what little is left) so I went and found the manual. Not sure what it means but a couple of lines down from your 1142lbs it has 1503lbs at the pins. Must be at a different point in the arc. Yes the light ones should be fine.
DRL
   / What about these Forks #8
If you want a low cost, tough alternative to pallet forks, here's what I've done on the L3400.
Buy this:
King Kutter Incorporated
Set it in the bucket, use two, ten-foot sections of chain and a load binder to strap it to the bucket, one chain on each side looped around a fork and an upright, and behind the bucket.
If you don't need adjustable or thin forks, it works fine, and fits standard pallets. Works well for transporting brush and logs, too.
I can install in about three minutes. When not strapped to the bucket, makes a great carryall with a pallet on the three point hitch.
   / What about these Forks #9
Buy this:
Do have any pics showing exactly how you chained it ? Looks like the low budget solution I 've been looking for.
Thanks Foodplot, I also thought about clamp on forks but they and your idea will push the load farther forward reducing they capacity of the FEL.
DRL
2025 Swict 84in Bucket Skid Steer Attachment (A53421)
2025 Swict 84in...
2012 FORD F450 XL SUPER DUTY TRUCK (A51406)
2012 FORD F450 XL...
Hose Reel (A55787)
Hose Reel (A55787)
2005 Sterling Acterra Tender Truck (A57024)
2005 Sterling...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2023 New Holland TS6.140 T4B MFWD Tractor w/ 830LA Loader (A53485)
2023 New Holland...
