What about antifreeze?
   / What about antifreeze? #11
Dusty said:
The color of antifreeze is no indication of the type of antifreeze that is installed. Here is a technical bulletin from the Filter Manufacturers Council that explains the different types of antifreeze and other details about the product. Possibly it is more information than the average person would want, but it will take less than 5 minutes to read it and it will give you a new perspective on antifreeze types.
Dusty
My poor Gruman body Freightliner with a ISB 5.9 Cummins feels left out, it's color isn't listed in that article. It has purple antifreeze. :)
I was unfortunate enough to be working at a International truck dealer when over the road tractors started switching from good old green antifreeze to the newer extended life antifreeze. What a disaster that was. First orange, then pink, then yellow, then blue... Drivers adding the wrong coolant when they needed a top off, others adding DCA to coolant that did not need it, others that did not add the needed extender additive at the scheduled intervals to extended life coolants. Then you had companies like CAT that realized the early silicate free coolants were causing water pump failures and had us add a silicate additive to the collant to update it. Just a big debacle. Numerous water pump failures, coolant gelling from mixtures of incompatible collants and cylinder liner cavitation leaks. I wish they would just bring back the good old day's of green antifreeze, test at every service interval with a DCA test strip and add DCA as needed.
   / What about antifreeze? #12
Dusty
Dusty, the link is very informative and worth the time to read it. Thanks for the enlightenment. ;)
   / What about antifreeze? #13
Upon further investigation, actually I didn't look before and relied on my sometimes faulty memory, my Kioti is filled with normal green coolant. Must have been the sun shining off that orange hood that deceived me :).
Dusty, thanks for the link, good info.
   / What about antifreeze? #14
Who said that Kioti and Kubota guys can't get along???? :D :D
Deere 335P (A53317)
Deere 335P (A53317)
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E83NKE63062, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
Enclosed Service Truck (A55788)
Enclosed Service...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2014 Ram 2500 Pickup Truck (A55973)
2014 Ram 2500...
2016 JOHN DEERE 310SL BACKHOE (A52709)
2016 JOHN DEERE...
