What a Joke
/ What a Joke #21
The Toyota dealership where we got the wife's Camry is telling me that the 3/4 and 1 tons are coming. They won't say when. And there will be a diesel available. The service manager tells me the engine is already in testing and that from what he has heard, that it will blow away the latest Powerstroke and Cummins. That I would have to see. I have seriously considered trading our 2003 F-150 for the current Tundra. It is a far better rig than my F-150. IMO
Anyway when Toyota come out with the 1 ton, then compare it to your 1 ton express van. Lets try to keep a little apples to apples here.;)
/ What a Joke
My original point was how can Toyota basically brag about 10,000lb towing capacity on a 1/2 ton and GM say their 1ton diesel is the same capacity. Clearly someone isn't telling the same story.
And then I'm saying I really have put the van to the test day after day and it really can tow 10,000 or more reliably. Yes it is better equipped for the job clearly but the average person looks at those crazy commercials and probably believes them.
A couple of yrs ago I did my own test. My brother has a 1/2ton chevy. We towed the same load behind both my van and his truck approx. 6,000lbs. Starting out the load was about the same. The 1/2ton had a little chop though. Going down the road the van felt very stable and solid. The truck had some feeling like it was being overpowered by the load. And stopping was no contest. The van weighs about 1500lbs more too. So unless Toyota has some real trick they are pulling (Ha.Ha) those commercials are a joke!
/ What a Joke #23
I think this guys is close to his "10000 pound" capacity.:) Picture22 (Small).jpg
/ What a Joke #24
Diamondpilot said:
I read a few months back on content and man hours used to build 1/2 ton trucks. In the 1/2 ton market the Ford F-150 and Toyota had the highest percentage. The Dodge had the lowest, I believe it is assembled in Mexico. The Fords and Toyota's being assembled in the US is what gave them a high percentage. I am not sure but I believe the GM trucks are assembled in Canada.
I agree it is the government running our companies out of town. The company my dad is vise president of did the same thing but are now thinking of coming home. The grass was not greener on the other side.
Chris
My GM truck was assembled & built in Flint, MI. It contains ~85% domestic parts.
Gimmie a ring when Toyota & Nissan reaches an 85% domestic parts content. ;)
I don't really care as much as I used to, but I felt the need to help add some truth to what I'm reading.
/ What a Joke #26
Chris
My 07 Ram 1500 was assembled in Louisiana. Domestic content 72% I believe.
/ What a Joke #27
Last I saw the Tundra was 80% domestic and the Sienna was 85%, but that's apparently changed. Either way it's just marketing, all manufacturers buy the parts that will get them the most money. Sometimes that means buying in cheaper countries to save money over US-made and sometimes it's flag waving and saying "look where we were made".
Given the lack of catastrophic frame failures and class action lawsuits against Toyota I've got no reason not to trust their numbers, but if I had to tow 10,000lbs I'd look for something able to tow a bit more no matter what brand it was. If it helps, the 3500 truck can tow 12,000 lbs, obviously GMC just thinks a van isn't as good a towing machine as their truck.
/ What a Joke #28
Just what we need, an even more powerful diesel. I can't see anything reasonably done with even a 1-ton requiring or getting much benefit from more than the 350hp currently available in pickup diesels. I would much rather see a smaller motor that is more efficient. But of course hp sells to people who don't know what they really need. Explain to me how all the medium duty trucks work just fine with a measly 250-300hp.
/ What a Joke #29
JerryG said:
Just got back from town buying some groceries. While there I saw a Toyota Tundra with the 5.7 fender badges. The guy had a trailer with 8 round bales of hay which looked to be 4x5s. The rear bumper was almost on the ground. I kept thinking that something was going to pop at anytime. It was way over loaded. I don't understand people trying to do things with a pickup that they clearly wasn't designed for. Maybe the guy believed the commercial.
Maybe the guy had never heard of weight-distributing hitches and neither the dealer nor anyone else bothered to tell him. I always crack up when I see heavy duty pickups towing travel trailers in the 8-10k range, easily within their ability, that have the rear end of the truck dragging because the driver was too dumb to learn about weight distributing hitches. A 2k tongue load on a weight carrying hitch doesn't work in any 1-ton or smaller setup I know of. I wouldn't be too surprised if a lot of Toyota dealers have never heard of weight distributing hitches, since it's only very recently that they sold anything big enough to tow an amount requiring that type hitch. (Not to mention that in my experience most Toyota dealers are among the very worst of all car/truck dealers...)
/ What a Joke
I think the limitation might be the hitch issue. On a PU you have the gooseneck option. Otherwise a PU and a van are the same except for the sheetmetal.
I have a friend who for yrs now won't except a van as a truck. IMO vans are a great cheaper alternative to a truck if you are willing to not have 4WD. My 2002 Express 3500 van was 18,000 new and serves me every bit as well as a PU that would have cost close to 30,000 comp equiped. I have since found out you can have a van upfitted to 4WD before delivery by the factory and retain full warranty. They didn't tell me that at the dealer. I found it out on line.
/ What a Joke #31
The Toyota is NOT rated to pull a 10,000 lb trailer, its a 10,000 lb combination. Since the truck weighs 6000 lbs itself when loaded with fuel and passengers, you can only haul a 4000 lb trailer with a Tundra.
GM rates its towing differently. No industry standard. Some manufacturers give max TRAILER weight with the truck at empty gas tank and just driver load.
The Tundra does not have enough brakes to stop ITSELF very well, much less with a trailer. Something your RECALL notices should have pointed out.
The trailer in those fancy ads was aluminum and EMPTY.
/ What a Joke #32
I think you're getting confused with the older Tundra which I think was only around 6000lbs, I find it hard to believe my SUV without a solid axle can out tow a Tundra. If you've got a source for this information it's be an interesting read.
/ What a Joke #33
Like I've said before, they can't make a transmission to reliably hold the torque generated by anything more than what's available now without a lot of expense added to the pricetag and weight added to the truck and loss of interior space.
The Allison 1000 series in the GM HD's is about as beefy as it gets and look how it only sits 11" off the pavement. It's a monster in a light duty truck. It can hold a max 660 ft lbs and that's with torque managing strategies in place. it's the same transmission used in medium duty trucks.
In a world that makes sense, GM, Ford et al. will offer 2 diesels: one lower powered version for fleet useage and one that offers max power for all the guys on the truck websites.
GM currently offers the 4500/5500 6.6L DMAX with 2 power options 300/605 & 365/660. Watch for a new line of V-8 high revving diesels for 1/2 tons next year.
/ What a Joke #34
Original Tundra with 4.7L V8 was rated to tow I think 7300lbs with automatic transmission. That would require a weight distributing hitch, of course, and that is really a max rating. The new Tundra with 5.7L V8 and 6 speed auto is rated by Toyota to tow a 10k trailer. I'm not saying it will do a good job or is a good idea, but that's what Toyota rates it for. I think you may be confused by the allegation that in one of Toyota's ads, the voiceover said "it's hard to push 10,000lbs up a __ % grade" or something like that, and in fact the trailer was 4k and the 10k claim included the weight of the truck.
/ What a Joke #35
Diamondpilot said:
One thing that was weird was the way they had the drive train set up. The only rear end gears they offered were a 2.94 and a 3.35. The 2.94 was equal to a 3.73 in other trucks and the 3.35 was equal to a 4.10.
It's a matter of matching effective tranny gearing to the rear end ratio. The Titan probably had a lower 1st gear and maybe 2nd gear than the other trucks, to effectively pull the rear end ratio. With taller rear end gears, they probably also had a milder OD than the other trucks. It also depends on the torque curve of the motor.
/ What a Joke #36
I have a new 2007 Tundra Double Can version. It is rated to pull 10,300 and that is the trailer only not including the truck weight. I pull a 30 foot goose neck trailer that is 6000 lbs empty, my trailer gross weight is actually in the 11,000 plus category. I traded in a 2004 F250 crew cab with the 5.4 gas. This Toyota will run circles around the F250. I am talking gas engines here. If my Ford would have had the diesel I probably would have kept it.
Don't say too much bad about the Tundra until you have owned one. I feel there is absolutely no comparison to any other half ton and I have had Ford's and Chevy's in the past. I look at the Tundra as being somewhere between a half and a three quarter ton. It only needs heavier tires and a little more spring. The brakes, rear end, transmission and engine are there now.
/ What a Joke #37
Does anyone know all the facts on a "tow rating"? I remember some years back carefully inspecting a manufacturer's tow documents and discovered the tow rating was at 45MPH:eek:
I've always told people you ain't gonna be very happy towing over HALF whatever the manufacturer says....it may DO it but it ain't gonna be FUN:D
/ What a Joke #38
We are talking 1/2 ton trucks not 3/4 or heavier. I am sure you are right, all the heavy duty trucks by GM, Ford, and Dodge are assembled in the US at this time.
Chris
/ What a Joke #39
It was slated to be closed and all operations moved to Mexico in the 4th quarter of 2007. I am sure your truck was assembled there if assembled prior to October 07. Sounds like you got one of the last good ones.
Chris
/ What a Joke #40
Chris
Sorry, I thought we were talkinh light trucks & vans, my bad.
BTW:Dodge 3/4 & 1 tons are assembled in Mexico and have been since about 2000 give or take a year.
LOT LOCATIONS (A59914)
Mini Universal Tree Spade (A65640)
Mini Universal...
2001 WESTERN STAR  4900E (A65643)
2001 WESTERN STAR...
Truck Tool Box (A65640)
Truck Tool Box...
2008 Bobcat T300 (A64126)
2008 Bobcat T300...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
