What痴 the Difference Between a Lawn, Yard and Garden Tractor?
   / What痴 the Difference Between a Lawn, Yard and Garden Tractor? #2
A garden tractor has the frame and transmission to do ground engaging work with a rear lift hitch of some type(either sleeve hitch for catagory 0 three point hitch). This includes rototillers, one bottom mold board dirt plow, disc harrow, chisel plow/ground ripper and so forth. A lawn tractor cannot handle this type of stress. Lawn tractors mow your grass pull a lawn cart and with care, push or blow snow. Some of the higher end lawn tractors can just barely handle a lawn roller but most will just overheat and burn up the cheap hydrostatic transmissions they use these days. Those lack enough capacity of fluid to stay cool under a load, such as pulling a heavy lawn roller. Many older garden tractors, and a couple current ones like the Cub Cadet XT3 are shaft driven between the engine and transmission instead of a belt, and use a horizontal crankshaft engine(like a big tractor) instead of a vertical crankshaft engine(like a push mower). Mike
   / What痴 the Difference Between a Lawn, Yard and Garden Tractor? #3
Well, they all have an A in them, but the rest of the letters are different :D
   / What痴 the Difference Between a Lawn, Yard and Garden Tractor? #4
The price?
It's a lawn mower not tractor, which stays cleanest while garden tractor stays filthy. Yard tractor is in the middle. None are a real tractor tractor, like a moped isn't a real motorcycle.
Did I win anything?
   / What痴 the Difference Between a Lawn, Yard and Garden Tractor? #5
Much of the difference appears to be what the seller wants to call it. A Craftsman yard tractor is basically a riding mower - perhaps a larger one. Their garden tractor looks the same and may even have the same engine. The transaxle is heavier duty but otherwise they're pretty similar.
   / What痴 the Difference Between a Lawn, Yard and Garden Tractor? #6
Garden tractor is designed for yards with gardens and can handle maintaining yards and gardens. With a garden you will have some capacity for ground engagement equipment. My take is a garden tractor supposedly has a thicker frame and beefier transaxle as well as bigger rear tires.
   / What痴 the Difference Between a Lawn, Yard and Garden Tractor? #7
Here is what the picture of a garden tractor should look like if you look it up on the interweb.
Well, they would look like this only oriented properly. Can't seem to get them turned right.
   / What痴 the Difference Between a Lawn, Yard and Garden Tractor? #8
In my mind, garden, lawn and yard tractors are "tractors" in name only.
A real tractor STARTS with some of the size pictured above, or maybe a MF 35 or 8N. Tractor suggests TRACTION. BIG WHEELS. At least TWO.
A really good rating system (for tractors as well as UTVs) would be how much SNOW can one dive through. I know snow can vary in type.
   / What痴 the Difference Between a Lawn, Yard and Garden Tractor? #10
2005 HACKNEY AND SONS, INC. BEVERAGE TRAILER (A53843)
2005 HACKNEY AND...
2018 Kia Soul Hatchback (A51694)
2018 Kia Soul...
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2010 PETERBILT 367 HOT OIL UNIT (A53843)
2010 PETERBILT 367...
2000 Mack CH613 Day Cab Winch Truck (A53117)
2000 Mack CH613...
