Wet brake replacement
   / Wet brake replacement #1
s2man
West Central Missouri
JD 285 lawn tractor
What did I get myself into? I bought a used Jinma 454 for (I think) a good price. But it looks like it needs new brakes.
Is this an all-winter project tearing the rearend apart? Can I even do it myself? My neighbor says I have to take it into a shop. If so, any rough estimates on the cost? Any other advice?
   / Wet brake replacement #2
I haven't personally done wet brakes, but I've split tractors before to do clutch packs and transmission work. Whether you could do it yourself depends on your mechanical aptitude, and your availability of tools. If you have decent mechanical ability, a relatively smooth concrete work surface, and decent tools you should be able to do the work yourself. You'd need decent jackstands, blocks of wood to support, a decent floor jack or two, and an engine hoist or chain hoist off the ceiling to support the axle housings.
   / Wet brake replacement #3
Are you sure that that Jinma has 'wet' brakes?
erj, yes. the manual says they wet and the neighbor/farmer showed me the difference on his tractors.
jb, I was looking good until you said, "hoist". Dang. Well, I have a steel frame, about 7' tall, and a comealong. but then I would have to work around the frame. Hmmm.
   / Wet brake replacement #5
How many hours on this tractor to wear down wet brakes. Must be a lot.
2007 FREIGHTLINER M2 BOX TRUCK (A53426)
2007 FREIGHTLINER...
2007 Allmand Night-Lite Pro Towable Light Tower (A51691)
2007 Allmand...
1968 CHEVROLET C10 1/2 TON PICKUP TRUCK (A53426)
1968 CHEVROLET C10...
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
2011 Wacker Neuson RD12A, 36" Double Drum Roller (A52384)
2011 Wacker Neuson...
