Went down to Tazwel yesterday
   / Went down to Tazwel yesterday #71
When I was tractor shopping back in 2001, I had it narrowed down to a NH TC21D, Kubota BX2200, JD 4100, and a Cub Cadet 7205.
I couldn't fit on the JD. My knees hit the bottom of the steering wheel with my feet flat on the floor.
I wasn't very comfortable on the Kubota, either, and I operated one at our little league park and did not like the treadle on the right foot.
I couldn't find a Cub Cadet. Looked good on paper. Couldn't find one.
The NH TC21D was the most comfortable and ergonomic of the conventional tractors. It fit my body well, and everything just seemed to be in the right place.
All of them had diesel engines compared to the gas engine on the PT.
All of them were 35-50% larger displacement engines as well.
The PT had 33% more GPM hydraulic flow on the main hydraulics and higher pressure as well. And the PT had aux hydraulics as well, that were 4gpm at 2500psi.
The other machines all had multiple ranges. The PT only has one, hence, the pulling power difference.
Top speed was similar on all in forward. The PT can go the same speed in reverse and maintain control. The others can't.
The PT was shorter and narrower (you can dish in the tires on the NH to get it narrower) than the others, making it more maneuverable in tight spaces.
The ROPS/FOPS steel canopy on the PT is lower than all the others. It's saved my noggin several times.
The height of the ROPS on the NH is over 81". I can put my nose on top of the PT canopy, making it about 66" in height. That's a 15" lower ROPS, making it easier to get in and out of low hanging branches, and not having to worry about it hitting a garage door or shed door.
The only one that weighed less was the BX2200.
I can drive the PT backwards up into the bed of a standard pickup truck with an attachment attached. I've done it with the 60" mower, 48" brush cutter, and I've nested my forks and sod slicer in my small bucket into my large bucket and backed up into my pickup truck and off I go. So that was the machine and 4 attachments in one trip.
And it cost a lot less once everything was all said and done.
Back in 2001 I got the machine, 60" finish mower, 48" brush cutter, 60" power angle snow plow, 10 cubic foot light material bucket, 5 cubic foot rock bucket with teeth, pallet forks and loading ramps delivered from VA to SBN for less than $13,000. Ordered on a Friday afternoon and it showed up Monday night. :)
I did my homework back then and made the correct decision for my needs. Had I gone the conventional tractor route, I would have gone with the NH TC21D. It was a strong 2nd place.
   / Went down to Tazwel yesterday #72
If I was moving 20 yards of stone 100 yards a 1500 pound machine with a 1/3 yard bucket wouldn’t be my first choice. And I don’t think a long haul is your time to shine. I know that loading with my backhoe vs a skid steer the skid steer might make up some ground with productivity in close places. For going 100 yards I can haul more and go faster.
It wouldn't be my first choice either, but that's the contest. ;)
   / Went down to Tazwel yesterday #73
Well I’m cheating and loading my dump truck with a yard bucket. Better yet I’ll just send the tri axel it came on 100 yards farther, lol. Yea, I know tri axels are pretty limited where they can go off road.
I think your missing the point, no matter how many times it is said. If you want a dedicated machine to do one task well, that's up to you. We have chosen to have a machine that does many task, some extremely well, some good, and some just OK. But I think consolidating into one machine is the way to go, to each is own.
   / Went down to Tazwel yesterday #75
"20 yards of crushed limestone and let's see who can move it 100 yards fastest."
It sounds like this was assumed by some to be moving it across a parking lot. What if the 100 yards was down a narrow lane? Under low hanging trees? Across a side slope? Through a small stream? Up a steep hill? Or maybe all of those combined? That would make the PT the clear choice in my mind.
This thread has no doubt raised awareness of the PT line, and probably will result is some future sales for them. :thumbsup:
   / Went down to Tazwel yesterday #76
You don't feel guilty about cheating? :laughing:
I hear you. :thumbsup:
   / Went down to Tazwel yesterday #77
That is the first PT I bought, love it. I put a dent in my Kubota bucket by using it to load rocks that were inaccessible with the big machine and didn't want to damage the lawn. Slid it in slowly but rang the bell, and a dent! It is a nice cheap machine for the money $6500) what else could you buy, a new skid steer?
   / Went down to Tazwel yesterday #79
And it makes you look more muscular :)
It's the hat
2018 John Deere XUV560E 4x4 Gator Utility Cart (A56857)
2018 John Deere...
2015 Nissan Altima Sedan (A54815)
2015 Nissan Altima...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
Case 950 8 Row Air Planter (A55315)
Case 950 8 Row Air...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
