Well with Pitless Adapter?
   / Well with Pitless Adapter? #11
you guys are good
for someone who doesnt know you have been a great help
Thankyou! That looks like what i see down in the casing. I looked at both break downs the one with two holes must be for an above grown pump with a deep well attachment? Thanks again this has been a great help and a load off my mind.
Richard
   / Well with Pitless Adapter? #13
Yes, the two holer is for a deep well jet pump and works basically the same way as the one holer. I have pulled mine a few times and it is a two holer with two pipes in the well. Not a job I want to do every day but not that hard either.
I would imagine this pump has plastic pipe. I've no idea how deep the pump is but the snubber is not far from the pump I would think. So it must be not far from 45'.
   / Well with Pitless Adapter? #15
the snubber you are hitting might be a centering ring or cable guard
they keep the wire from rubbing the case or bore by keeping it centered in the well
tom
   / Well with Pitless Adapter? #16
"see above image"
Yep! It's been about 26 years since I've seen it, but that's just what's down my well, too. Looking at that pic brought back all sorts of fond memories...:p
The tank and valves are in a square pit with a hindged plywood lid. I lifted the lid and looking down, there was a snake and a web with a large black widow spider, I'll bomb it before I go in to clean it out.
Still in escrow.
   / Well with Pitless Adapter? #18
Not are all that easy.
Some have a small wedge that needs a square wrench on the end of a 6' handle.
Also it's very easy to drop the wedge down the well!
You still need the tee handled pipe to pull the adapter, pipe , and pump.
first time I pulled our pump was lastnight, it has that style wedge lock- I have looked and found ZERO information on the web about this style, until stumbling upon this mention a day later...I believe ours was original, installed way back in 1971- is that possible?
had to weld up a squaredrive tool (1/2" adapter, welded to a pipe with a L-handle) what a pain in the butt to get back into the discharge port and seal...took half a dozen tries before finding the sealing position... the adapter has about a 1/4" projection that hooks into a hole in the casing, but its just there to locate it/prevent sliding down after its wedged from the looks of it. if the projection isnt in the hole, the seal is visibly away from the casing wall. the sealing O-ring has loops that lash it onto the adapter, no idea if the rubber is available for replacement- luckily ours finally sealed after numerous tries- my back is killing me :)
do you have any info on these styles? I think when warm weather gets here (if ever) I'm gonna dig/run new wire/pipe/etc, (only a couple feet deep to the discharge) as whats there is over 40 years old and fugly...think I'll put a newer - easier to hang pitless adapter in, just wonder what I'll need to do to close off the old pitless hole/bung/whatever they have on it... thanks in advance for any info.
BTW- ours had the wedge safety wired to the adapter- I was scared to loosen the bolt too far for fear of unknown... could it and/or the wedge fall down in? was a kinda false worry luckily, live and learn I guess...
if by some odd chance some other 'beginner' like me stumbles into this thread looking for info on 'wedge type pitless' adapters: the bolt has a flared bottom, so fully loosening is fine, and the wedge is pocketed so it cant fall off till its out of the case (just at the top I can see how easily one would plop into the well if not safety wired). I had put a small NefeB magnet in the 'socket' and just turned 90 at a time- figures, soon as the adapter was free, the bolt had 90 degrees more to its stop :)
the last owner musta P.O.'d the well guy... the 5" casing top had a 4" threaded stub welded on to a adapter welded to the casing, the pitless adapter was impossible to pull out without cutting the very top off the casing...what a joy that was...2am this morning, we had water again, I tack welded the bottleneck small 'top' back on for now...what a evening... at least it didnt happen a week ago in subzero weather- I'm sure well guys gotta deal with stuff like this in all weather/all hours, hats off to you... not fun pulling even a relatively lightweight 90 foot slippery/slimy drop in the cold even with extra hands :(
   / Well with Pitless Adapter? #19
"see above image"
off topic- see you are into rc stuff and old jap bikes- I have a 89 yr old buddy with a 68 honda ca 160 with 135 miles on it- he parked it in 1972, after a busted valve stem on the highway scared him to death of riding... any idea what something like that might be worth? looks good, but surely motors gunked up- garage its in is unheated, and it hasnt been turned over in 40 years, all original except for one tube.
I was into r/c a long time, but lost my 70 yr old flying buddy back in 06, havent been out since... planes/helis lots of fun times... had a r/c car for a few months, way too expensive. flew my helis for years on less $ than that goofy car cost over a few months...
   / Well with Pitless Adapter? #20
I recently had to mess with a friend's well and pump.
While the problem could have been a bad foot valve we were convinced that the pipe had leaks, because at at every start up lots of air entered the line and tank.
Being such an old installation all the line down to the pump was steel and we discovered a few rotted out areas near the house that sucked back pressure. We temporarily solved the problem by inserting a check valve in the line before the tank however at every pump cycle all the air in the line would get pumped into the tank and system. A shower ensued every time we opened a tap.
We excavated some and sure enough the steel line was well rotted at many areas.
The estimate is that the pump is 300 ft down (known water table in the area) and that would sure be a monster job to retrieve the pump with steel down line. And I'm sure no pit-less adapter was used.
As luck had it a city main is about 150 ft from the building with a valve at the curb so we plumbed the city water back to the building using blue poly B pressure line.
If you want a free 3/4 hp pump and have strong arms come pull that pump. LOL
To make matters worst the well head is 4+ ft down in a 3 ft wide concrete pipe with 1-2 ft of silt covering the well top as the installation is in the middle of a parking lot.
The 'cover' is a 3/8" steel plate flush with the gravel and all sorts of crap simply filtered down. Needless to say we never attempted to pull the pump.
Judging from the feed line to the house I picture the down line to be mostly swiss cheese and rust.
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2013 INTERNATIONAL REEFER TRUCK (A57880)
2013 INTERNATIONAL...
Year: 2005 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2005 Make...
PAINT ROOM EXHAUST FAN (A54757)
PAINT ROOM EXHAUST...
ST225/75R15 Trailer Tires (A55787)
ST225/75R15...
