Well Water Has Suddenly Gone Brown
   / Well Water Has Suddenly Gone Brown #11
Everybody on a well should have a cartridge filter. Preferably, a 4" x 10", or better a 4" x 20".
Could be normal activity in the ground stirring stuff up.
Could be a bad tank, bad pump (possibly the starting switch), bad check valves allowing the water to run back to the well.
Could be a hole in the drop pipe.
Water filters that don't backwash properly can start to puke stuff back into the water.
I can walk you through trouble shooting some of this stuff.
Steve
   / Well Water Has Suddenly Gone Brown #12
You have a galvanized tank with an air release?
Submersible pump?
That means there is a bleeder in the well.
   / Well Water Has Suddenly Gone Brown #13
Yes, it could be excessive flow. Look for toilets leaking (running) or outside silcocks that have just thawed out and are running
   / Well Water Has Suddenly Gone Brown #14
Brown water is better for you, kind of like brown eggs. :)
   / Well Water Has Suddenly Gone Brown #15
Brown water is local water, and local water is fresh...
Unless you live in Detroit. :(
   / Well Water Has Suddenly Gone Brown #16
If there is a check valve (or even the foot valve) the springs can rust...
   / Well Water Has Suddenly Gone Brown #18
Our well water does that after a natural seismic event or by nearby blasting. Clears up in two days usually.
I’d guess excessive flow. Either because it has been rainy, or the well has drawn a lot of water.
Can you tell if your pump has, or is, running more.
I did just start using the sprinklers, but then again, I do that every year and this is the first time I've gotten brown water.
Electric Concrete Mixer (A51573)
Electric Concrete...
FRONTIER WR3210 LOT NUMBER 120 (A53084)
FRONTIER WR3210...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
