Well that was pretty dumb!
   / Well that was pretty dumb! #21
So my grandpa and I are working on fixing up a JD 550 dozer and we had the track frames out from underneath the machine so that we can tear them down. I had gotten the correct spring compressor bolt from JD to compress the track springs however the threads in the spring cup are very fouled and the bolt won't work. So we improvise and get the first spring off without to much trouble by using a 1" diameter piece of all thread. The second spring was more ornery. Instead of the nut backing off, the shaft starts backing out and there is only a inch of thread in the cup. So I get the bright idea to take the 480 case and use the hoe to try and take some pressure off the bolt by compressing the spring with the hoe. No good, it's just picking the hoe up off the ground. Grandpa gets an idea! Let's set the 3/4" impact gun up on the bolt and tape the trigger in, then head for cover and plug the air hose in! Brillant. Obviously we both realize this is deadly serious but we don't have to many other options! I hide in the shop directly behind the idler on the track frame which is in line e with the spring. (The track frame made a sturdy table.,) so I slam the air hose in and the impact starts hammering away and wouldn't you know it, that bolt popped loose releasing the tension on tbe track spring and bounced that 480 hoe up in the air a few inches!! Whew! Should have recorded that but I didn't think about it when my life was in the balance!
   / Well that was pretty dumb! #22
I have lots! A few weeks ago I was putting fuel in my Massey and got it really, really full...like just enough room to get the cap on without spilling anything. It was pretty cold out, but I never thought about it. A week or so later I was pulling the steering cylinders off to take them to the hydraulic shop (both were leaking) and I found fuel running down the side of the engine, and drips all over the ground under the machine....everything was wet! I immediately started checking fuel lines, and trying to figure out where the fuel was coming from. I was thinking that there should be no way the tank had rusted through, but that I was going to have to take the hood, and side sheet metal off, etc, etc. Then I remembered fueling it and thought that maybe I had spilled some. Nope, I realized it was 25* warmer than when I had fueled it, and the fuel surged over the top of the neck, and poured all over the top of the tank, which is why it was leaking everywhere.
I know better, but wasn't thinking....luckily it was just some mess to clean up, and the machine is actually cleaner now after wiping up all that fuel! I felt really dumb, but at least nothing was damaged :)
I did that with my boat..topped it off real good before winter to prevent condenstion...no airspace..yea, soon as it warmed up outsided I had gas running out the vent all over the garage:mur:
   / Well that was pretty dumb! #23
Years ago I had a JohnDeere 410 backhoe and a friend built a new home. The neighborhood had all underground utilities, electric, phone and cable and he asked if I would dig out the 200 foot trench in exchange for a nice older Farmall cub I had attempted to buy from him in the past.
Easy job 200 ft. Trench and fill it no problem or so I thought. After digging the trench I tried talking him into laying PVC for the lines to be pulled through but he didn't want to because utilities told him it wasn't needed. Well one day goes by no utility's two days,three days and on the fourth day a hurricane, yep a hurricane and half the trench collapsed and now he is on the phone telling me that the utility companies call and scheduled for the following day. I went back to the house after work and was in no way going to hand shovel the trench to clean it out and in looking at the width of the trench and the width of the 410 wheels I had no problem straddling the trench to clean it out. About 150 into the clean out I hit a pocket of real sandy soil the trench collapsed and the 410 was lying on its side. Boy that was a pucker factor of 10.
Once I stopped cursing and looked it over refusing to call a heavy duty tow truck I was able to right the tractor using the bucket backhoe and stabilizers. Interesting, educational and very very DUMB.
Sent from my iPad using TractorByNet
   / Well that was pretty dumb! #24
My turn. I was unhooking the brushog for the last time of the season and was in hurry. The 3PT was being difficult. I finally got it off, fired up the tractor and drove off. 3 feet and I hear this pop. Look behind and see one half of the PTO shaft attached to the tractor and not to the mower, and the other half attached to the mower but not to the tractor. I had forgotten to unhook the PTO shaft and it had pulled apart at the joint where it extends! I finished cursing, unhooked the half attached to the tractor, and shoved it back on the mower. I'm finished with the hog for the year, so I'll see how it is this spring. I'd be surprised if it doesn't work just fine though.
   / Well that was pretty dumb! #25
Thermal expansion, all liquids, solids and gases. Fuel tanks are not meant to be filled 100%, you always leave a little bit of dead space for this very reason.
There are a few materials known to exhibit no thermal expansion properties. Just as a point of trivia.
xtn
   / Well that was pretty dumb! #26
Is this with diesel or gas as the fuel. I didn't think that would happen with diesel. I'll have to remember that in the future because when I refuel my tractor, I usually take it all the way to the top - and I also *usually* do it when I'm done so it's ready the next time (something I didn't do this time)
It was diesel, and I knew better :(
   / Well that was pretty dumb! #27
I've posted this before.
Years ago when I was an apprentice lineman, we were out in a community pasture building a power line to feed a water well pump service for the cattle. To get to where we needed to go, we had a choice of taking a darn long way around a long steep hill...or go straight up it. The foreman and lead hand decided to try it first in the old 1972 International 3/4 ton pickup and see what it was like. They made it and decided it wasn't too bad and waved me on up.
I was driving the digger truck, a 1971 Fargo with single rear axle, duals and a 413 high compression engine that drank high octane only. The truck and material on it weighted a good 25,000 lbs or a bit more and we were pulling a pole trailer made out of an old truck frame and had it loaded down with a bunch of 35 foot power poles, almost two dozen of them so a good load there too.
The old Fargo had a real low first gear and we started up the hill pedal to the medal. It grunted and pulled down a bit then kept on pulling...right up until we got almost to the very top of the hill...which was just a tad steeper than the rest of it...I couldn't see anything but sky through the windshield. That was all it took...the fuel pickup in the tank uncovered and she sucked air and died! This old beast had vacuum brakes so when the engine died, so did the brakes...and the power steering. Without power steering, that old truck needed two men on the steering wheel to turn it on level ground. I quickly decided to try to get it into reverse to get the motor turning over to develop brakes and power steering since I didn't want to run it backwards and starve it for oil nor lose the power steering but...too late! The speed was already too great to get it into reverse from low.
In retrospect, that was a bad decision.
Being on that steep a hill, we quickly started to roll backwards and gain speed at an alarming rate. I had no choice but to try to back down hill without jackknifing it and rolling the truck. I was doing not too bad until the stupid newbie apprentice in the passengers seat decided he was going to jump! He opened the passenger's door, got one foot on the running bard, and then froze! He didn't know whether to jump, sh*t or go blind!
Needless to say I am now trying to back this rig up with just the driver's side mirror...screaming at the dip stick apprentice to close the effing door!
We got up to a considerable speed too on the way down...estimates from the other crew members were in the 45 mph range...did I mention the hill was steep?? Since we were in the middle of a community pasture there was also a herd of cattle that we had just drove through. The noise and commotion of us bouncing downhill half (ok, 90%) out of control was enough to scare them into running, so I missed skewering any of them on a 35 foot pole.
The other two guys on the crew were sitting in the third truck, a cornbinder, watching from behind us as we tried the hill. Why the driver never pulled right in behind me to follow me as I started up was a mystery, he said didn't know why even, but his decision saved him from getting rammed by a load of power poles. By the time I rolled to a stop, we were a good quarter mile from the top...
That was the farthest I ever backed a trailer up...fastest too!
I took a moment or three to get my heart to stop racing and then I fired up the old Fargo and we took the looong way around to the top...after switching over to the other full gas tank!
   / Well that was pretty dumb! #28
I can see it now, both hands on the wheel and both feet on the brakes.:eek:
Oh ya, and a few "oh God's"...lol
   / Well that was pretty dumb! #29
Did the apprentice have to go home and get some new underwear?:)
Heck for that matter did you need new underwear?:D
   / Well that was pretty dumb! #30
I don't know if Mace or the apprentice had to change their skivvies, but I sure as **** would have!
Electric tri scooter irgc40 (A56859)
Electric tri...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A56436)
Koyker Loader...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
