Well problem. Worth $2300?
   / Well problem. Worth $2300? #31
I wouldn稚 exactly say we irrigate with the well. Most days less than 10 gallons of water. I致e planted some grass seed in some small areas so it might be 20 gallons a day lately.
For that, I'd be collecting rainwater in barrels or a tote, or running to a pond/stream with a pump to fill barrels.
Nobody can accurately comment on the time it would take to pull YOUR well pipe based on how long it takes to pull theirs. There are too many variables.
   / Well problem. Worth $2300? #32
They aren't hard to pull.
You don't know that. You don't know that HIS pipe isn't partially collapsed or swelled from rust/corrosion or other blockage. You don't have any idea of the conditions at HIS place.
   / Well problem. Worth $2300? #33
2 years ago the well went out again. Bought a new 3/4hp pump for $400 and pulled the old one out by hand - 210' of black poly pipe. Replaced the pump and set it back down the well. Turned it on and nothing. Pulled the pump out again, and checked the electricity. Power at the top but no power at the bottom. Replaced the wiring for $150. Saw the old wiring has been spliced 6 times! Sent the pump down and everything worked fine. Total time 3-4 hours. It is not a hard job and you can do it for 1/4 to 1/3 the price.
Did you then check the pump you took out to see if it was good?
And again, you don't know the conditions at HIS place. HE may not be able to pull HIS out as easily as you pulled yours. None of us are there. The well guy was. Only his well guy knows for sure.
   / Well problem. Worth $2300? #34
If it is on steel pipe I wouldn't try to pull it myself. It will be heavy and need a hoist. Low pressure cut off switches with the lever on the side are more of a nuisance than a help, as they don't always catch a dry well condition. There are other devices like the Cycle Sensor and Pumptek that look at amps instead of pressure, and are much more reliable and don't give nuisance trips like the low pressure switch. For me, it is not so much a financial decision as a security one. I don't want to be dependent on someone else supplying me water. It is too important. I am working with a group of people in Colorado right now who just had their community water shut off and are having to drill wells. The local government, in their infinite wisdom, decided the water was just over the admissible level of nitrates or something and shut down the water provider. None of the homeowners had room to drill a well or install the pump controls. All 40 homeowners are having to find a spot to get a drilling rig in and figure how to put the controls in the house.
Oh and BTW, any submersible pump that has a pressure switch built in is a problem waiting to happen. Sounds like he maybe pushing one of those tankless type controllers or a variable speed type pump, which is like purchasing a high priced tar baby. Stick with traditional pump and pressure switch, just limit or eliminate the on/off cycling to make it last.
   / Well problem. Worth $2300? #35
If your rural water system is reliable and you're getting good clean water from it, I sure wouldn't spend a dime on repairing the well, especially for an occasional few hundred gallons of water.
I've had UNreliable rural water supply before, and they were simply a nightmare, breaking down all the time, sometimes for days at a time. We've been on a 100% well water system here now, with two wells. And they're always nickle and dime-ing you to death. If its not sand, iron, sulfur, bacteria, or a number of other problems to address, its a hardware repair problem. I'd certainly rather the rural water supplier have to deal with those than me shelling out mega-dollars to patch up my system. Of course, in our case, there's no alternative.
   / Well problem. Worth $2300? #36
Sand, iron, sulfur, etc., can cause a need for a little regular maintenance. But if your hardware is not holding up that can be resolved. Most wells don't give any problems and the equipment can last 20-30 years without any maintenance. A good well and a reliable pump system can be the best investment you can make. Noting else matters after about 3 days without water.
   / Well problem. Worth $2300? #37
Seeing a trend of people who have had pumps died because the well ran dry.
I strongly recommend replacing your pressure switch with one that has a low pressure cutout.
It costs a few bucks more, but if the pressure in your system drops below 20 psi it shuts down the pump. to start it back up you hold up a little lever on the side until it gets above 20 psi.
It's a whole lot cheaper than a new pump.
Aaron Z
Also should you bust a pipe, like frost likes to do, when the pressure drops it'll shut down and save you tons of water damage.
   / Well problem. Worth $2300? #38
Thanks downslope, that was kind of the answer I was looking for. I know how this works, someone comes on here asks if a price for something is fair, and people say they had that done last week for half of what they were quoted. I kind of expected posts like that. I was more looking for good reasons to fix the well I had not thought of.
So far our rural water has been 100% reliable. Itç—´ part of a very large system in terms of area, but mostly rural in nature. One of the water towers is within 5 miles. I do have an IBC tote I could use for emergencies but that would be a last resort. When we only had the well we were without water several times, probably once every two years on average, usually because of a lose of power.
I think its worth having a backup that may someday become your primary. I mean do you even know how good the water is? Has it been tested? Im wondering why a rural home switches from well to city water to begin with. Maybe the casing was broken and caused issues which is why it was switched to city water. How many gallons per minute was the well capable of, did it run dry and so on...
How much does 500 gallons of city water cost?
Im just curious thats all:) I would much rather stick with my own fresh water than to use treated water. Sorry I know its off your original subject but i am curious.
   / Well problem. Worth $2300? #39
The last time we had our pump replaced the well company added a "pump saver". It detects overspeed, dry well, over/under voltage, etc and shuts down the pump on a timer. There is also a hand held "informer" display unit that can query the memory on the pump saver so you can find out when it's seen transient errors. Our water system has a 10,000 gallon tank that is gravity feed to the house, so I can't tell that the pump is shut off until many days later when the tank is dry. I use the display unit to monitor the well. If it starts getting overspeed errors it's sucking air, and that means it's time to cut back on watering the lawn. So far we've had one series of drought years where that's happened. (the well service company also put an extra stick of pipe in last time to get the pump lower).
   / Well problem. Worth $2300? #40
In my case, about 5 bucks. I pay $25 or so for the first 1,000 gallons which includes all the account costs. Additional usage is billed at about $10/1,000 gallons.
UNUSED JCT 84" HYD DOZER BLADE (A54757)
UNUSED JCT 84" HYD...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2016 Caterpillar 930M Articulated Wheel Loader (A55787)
2016 Caterpillar...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A55787)
2014 JLG G12-55A...
2002 Volvo Tandem Axle Road Tractor (A47477)
2002 Volvo Tandem...
TRACKLESS MT5TD SERIES V TRACTOR (A51406)
TRACKLESS MT5TD...
