well pressure and....
   / well pressure and.... #1
farmerpsv
VA
NH TN65
Hey all,
I bought and restored an old victorian farm 4 years ago. one thing i never really addressed was the well. it's an old drilled well, and according to the neighbors it's never run dry. being an old tobacco farm, i had the water tested (in '99) for about 150 things and the water is great, been drinking it for 4 years. 6 months ago we relocated to another farm and i have a buyer for this one. when i went to check things out, i noticed a great deal of rust in the water. thinking back, i remembered when we moved in there was alot of rust in the water (the house had been abandoned for years when i bought it). i can't remember how long it took, but the water eventually cleared up, and by the time the water was tested, it was gone. i recently put a whole house filter on the well, it helped some. i have two theories about the rust. one: the well itself, being old, is a metal pipe, therefore the rust. two: the expansion tank bladder has a leak and i may be getting rust from the inside of the tank. the water pressure has never been great, we just lived with it. is water pressure a function of the pump or the expansion tank? i assume that in part it would have to have something to do with the tank since you get pressure with the well turned off. i also guess there's a backflow valve in the tank, but once the pump goes on you're really getting pressure from the pump? is this right? any thoughts on what i'm dealing with here? i want this to be right for the new buyer.
thanks,
paul
   / well pressure and.... #2
You didn't mention the water pipes themselves as a source for the rust. That would have been my guess. Pipes both buried and in the house. If you confirm you have a tank problem, a tank is a small cost compared to selling the place. Others here can better explain how to test the tank. You also might check out the Water forum at Countrybynet for other tips
Hi Herbenus,
the plumbing in the house is all new (pex) as part of the restoration, the tank or well are the only two possible sources.
thanks,
paul
   / well pressure and.... #4
I always thought that heavy rust in the well water originated in the ground - actual groundwater contamination.
   / well pressure and.... #5
My first well was high in iron content. Water was usually clear, but as I understand it, the iron can turn to oxide with time, especially if exposed to air. This is a bigger problem in the old tanks with air on top of water. Bladder type tanks should eliminate it. Chlorine can make it come out. Also, water sitting in toilet tanks would be exposed to air. But I suspect something in well is rusting up: the casing or the conductor pipe.
   / well pressure and.... #6
<font color="blue"> is water pressure a function of the pump or the expansion tank? </font>
Water pressure in the house is regulated by how much pressure is in the holding tank. Some tanks have a schrader valve (like on a tire) on them that will allow you to add some air in the bladder chamber, increasing the water pressure. The pump pressure will put the water in the tank until the preset pressure has been reached in the holding tank. Then as you use water, the pressure drops to the point that the pump is activated and pumps more water in the tank. The air chamber in the top of the tank will pressurize the system so you have water flow. If you have a leak in the bladder you would pobably not have any water pressure at all as both sides would have equal pressure. Most likely the low pressure is caused by the tank needing a shot of air.
Hope this helps you out.
   / well pressure and.... #7
"I always thought that heavy rust in the well water originated in the ground - actual groundwater contamination."
No, not exactly right. Hematite and several other ferrous minerals are common constituents of sedimentary rocks. The hematite acts as a cement holding the grains togehter and will precipitate out in the intergranular voids. Other common "cements" are calcium. If the well is in such an area that is rich in ferrous precipitates the water will have an iron taste to it, will often leave a rust brown stain on concrete and the hematite will precipitate in the pipes and plumbing as well. In most cases it is not harmfull to human consumption. Other calciums and chlorides etc can result in salty tasting water. In any case--it is NOT CONTAMINATION--it is a natural occurence. My well water leaves calcium chloride deposits when it evaporates but it is potable. A few miles from here their is a facies change--a geologic term for a change in depositional environment that resulted in a different rock type but of the same geologic age. That area is very sandy and hematite is the major cement constituent. Places that have sprinkler systems have stained sidewalks and drives. J
Bubba,
thanks for the info, that all makes sense, i'll give that a try.
J,
the water doesn't really have high iron content. we havn't had any of the staining over the years indicating iron, the water does leave some pretty heavy deposits, just not the staining characteristic of high iron. i'm certain the rust is not from the water but part of the system. given Bubbas' info, i think we're narrowing the source to the actual pipe that forms the well itself...which would explain why the water clarifies over time.
paul
   / well pressure and.... #9
I think the rusty water could be the result of the water settling out in the pressure tank. Now, when you start to use it you stir up what is in the tank. I don't think it is caused by the casing, just the water itself. The pressure is regulated by the cut off switch on the pump. Most pumps are set to 20/40. A jet pump has a check valve/foot valve at the bottom of the pipes in the well. Also when pressurizing the bladder in a tank, shut the pump off, drain all the pressure off, fill the bladder thru the shcrader valve until you are two pounds lower than the cut-off pressure. You will notice if your tank is waterlogged by the pump kicking on & off when you draw a small amount of water. Depending on tank size, you should be able to draw 3-5 gallons of water before the pump kicks on. Enough rambling for now...
Ron,
This isn't rambling, it's the kind of information and experience i new i would find here. i did put the filter between the pump and the tank, and it's red with rust. yet i am still getting rust in the house, after the tank. maybe it's both /forums/images/graemlins/confused.gif. i also theorize that if the tank bladder were ruptured, wouldn't it stop working? question: does the bladder hold water or air? which is being pressurized, the bladder or the tank. i had been thinking that the bladder held the water and it expands and contracts accordingly and that adding air pressure to the tank puts extra pressure on the bladder...do i have it reversed?
thanks for the thoughts,
paul
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
Car Tow Dolly (A52377)
2018 CATERPILLAR 299D2 XHP SKID STEER (A52705)
2018 CATERPILLAR...
