Well it worked
   / Well it worked #1
seedman4
I have a new mahindra 3525 tractor i bought last year.it did not come with rear remotes.called the dealer they said the option kit was around 600.00.So do it my self.i added a 5 gallon oill tank on the front end loader frame just in front of the right rear tire.then made a bracket for a log splitter valve and mounted it of the control bracket for the FEL.bought 2 HYD pumps that are rated 12 GPM.and 2 hoses.and the female HYD couplers.PUT IT ALL TOGETHER AND IT WORKS GREAT to run a single double acting cylinder...i bought 2 pumps because i had another tractor iwas going to do the same on but sold it...The other pump is for sale!!!!!
Any way spent $256.94 for the hole set up and saved money.by the way the added system is removable.and used only one pump..
   / Well it worked #2
How did you run the pump?
   / Well it worked
I ran it off the PTO shaft
   / Well it worked #6
Sounds good. I never thought about a rear remote like that, but it makes perfect sense and is easily upgraded to as many remotes as your heart desires.
   / Well it worked
Extra pump has been sold..
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
New Paladin Tag Quick Coupler (A50774)
New Paladin Tag...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2024 Bintelli Activ-EV Pulse (A50324)
2024 Bintelli...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
