Box Scraper Well I sorta tore up my box blade this weekend
   / Well I sorta tore up my box blade this weekend #1
allen in texas
Platinum Member
Levelland, TX
Kubota Grand L 5740, loaded R1's w/640 lbs cast weight, 854 loader
I have a BS72E from Cammond. I didn't know I was buying the "economy" blade when I bought it but that's my fault. And I put too much horsepower in front of it too. Again, my fault.
I was taking a lot down this weekend and after all the dirt was hauled out, I put my scarifiers down to rip it up to keep it from blowing. There were a lot concrete blocks left from an old fence and I hit everyone of them. I tore out the back of the cross bar where the shanks fit. Now the shanks are all floppy and hang at a weird angle.
Oh well, I guess I'll get out the torch and the welder. I won't mess that up again but I may destroy the rest of the blade. :)
   / Well I sorta tore up my box blade this weekend #2
Sorry to hear that.
   / Well I sorta tore up my box blade this weekend #3
That suxs. :( I have a 45 HP tractor and got a pretty heavy duty box Frontier blade that was rated for 70 HP tractors. I figured this would hold up to anything I could throw at it.
I was dragging dirt around a project and had it loaded and pulling away and hit a 6" stump a couple inches under the surface. I hit it right in the center of the blade. The blade and the metal holding it bent back about 3 inches at the center and was a mess. I though they were supposed to be so tough. Guess not.
Luckily I was able to figure our something with the log splitter and able to bend it back fairly good. I guess we have to have welders and torches and benders if we own a tractor.
   / Well I sorta tore up my box blade this weekend #4
Allen, i done the exact same thing to my 5.5' light duty King Kutter box blade. I also bent the 3pt. hitch all up. It's been like that a while now.
So finally got up enough money saved to buy a new box blade. I ordered a new one from Everything Attachments.com this morning.
Travis R
If I have to eventually replace my blade, I'll get another Cammond. I like the way it's designed but of course, I'll get a tougher one. I am not however going to buy one that will take EVERYTHING I run into. I'd rather the blade go south instead of something on my tractor. The problem is that my box blade is just too light duty for what I do with it.
I've been wanting a BB that is deeper to pull more dirt but until I kill it completely, I'll stick with what I have. (after I repair it of course)
You know, I just remembered one time I was doing some scraping and I hooked a 6" pipe that was sticking up about 1 1/2 inches out of a huge slab of concrete. I didn't see it because it was covered in dirt. I'm here to tell you, it stopped the tractor RIGHT NOW and I nearly bumped my nose on the steering wheel. Kinda hurt. I couldn't tell that the blade or anything else was hurt though so overall, I guess the BB is pretty tough.
Hmmm,
Just did a bit of exploring...
Cammond doesn't manufacture a blade rated for my tractor. :(
   / Well I sorta tore up my box blade this weekend #7
i broke my rear blade an 8' kk hd sheared the from side to side lock pin off i guess i need 150hp+ attachments i hope you get it fixed
   / Well I sorta tore up my box blade this weekend #8
Why don't they make the attachment pins into shear pins? That way guys like us who push our luck get a break. It could just be a breakaway bracket so it flips up like a snowplow or a plough. Much easier than fixing some heavy bent steel, like the one I have sitting behind my barn waiting on me to fix it.
   / Well I sorta tore up my box blade this weekend #9
I used a KK BB behind a 70 hp tractor for years without issue. When it hooked a rock or something the tractor just stopped... Suddenly. No damage. However, during our monster snow of 4 years ago, I was using it to push snow off my parking area and hit a big, frozen rock in reverse. It bent the frame of the BB sharply. However, I had a local farmer apply a little heat and straightened it out. Works perfectly again. Now I'm trading it ( a 6 foot blade) on a 5 foot blade because I swapped to a smaller tractor and this JD 3038 won't pull the 6 footer loaded up a hill. I need to pull uphill.
   / Well I sorta tore up my box blade this weekend #10
Is this the normal KK blade you are considering from from Northern Tool for$499 or the Professional series wihich is abour 4 hundred more? You get 3/8 sides and 50 more pounds instead of 1/4 inch sides and 500 lbs. In teh same boat. Have a 45HP KIoti and what to get one blade that will last.
thansk
Thanks
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
2011 WABASH 53 FT DRY VAN (A58018)
2011 WABASH 53 FT...
19088 (A55758)
19088 (A55758)
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2016 Toro Workman GTX Utility Cart (A56857)
2016 Toro Workman...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
