Well hung backhoe makes spring cleanup a snap
/ Well hung backhoe makes spring cleanup a snap #1
bebster
Platinum Member
Cape Cod, MA
JD 4410 eHydro & 430FEL w/ 4N1 bucket & pallet forks
After years of hauling yard clippings to the burn pile, I finally found a new method. Using 12x16 tarps filled with clippings, I tied the corners together with a 2' piece of electrical wire, and left them in the yard, and moved onto the next work area. Then when there were 2 tarps filled, I ran a rope under the electrical wire of one and then the other to make a sling. Then lower the backhoe bucket and hooked the sling onto it, and raised it. Then drove off to the pile. Easy! Here's a photo from behind.
Here's a closeup of the sling method from the front.
/ Well hung backhoe makes spring cleanup a snap #3
Pretty good idea as long as you keep on the straight and level. As I recall from your "barn" project you don't have much level land. I tried hauling off a tree in my backhoe bucket once. It was unstable enough to convince me not to try it again--but then I don't have any level land to drive on here. Be careful!
Well, you made through a winter with the closed up barn. Have any finished project pictures you'd be willing to share on your awesome barn?
Dave, No kidding about the level aspect -- I just stick to the driveway. If there's a hill, I can lower the BH and drag the tarps. As for the barn, I'll post a recent photo on that thread this week -- added a septic system finally (when the snow melted). But have started rebuilding the house (tore down the old one) so that's a major project.
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
Komatsu Hydraulic Excavator (A64553)
Komatsu Hydraulic...
2018 WANCO WTSV PORTABLE ARROW BOARD (A60429)
2018 WANCO WTSV...
2018 INTERNATIONAL LT SERIES (A65643)
2018 INTERNATIONAL...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
