Well frig..... Blew a bearing in my mower
   / Well frig..... Blew a bearing in my mower #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I had a feeling my center bearing was about to go. Mower just hasn't been running right. Anyone have a direction to look for new 1850 mower bearings? At the moment I am going to gut the whole mower.. Replace all bearings, pound out dents, I was just hoping to finish my last mow of the season.
I will take some pix of the tear down.
   / Well frig..... Blew a bearing in my mower #2
Look on the bearings for a number and go shopping either local or on the Internet.
   / Well frig..... Blew a bearing in my mower #3
Ditto.
Forget searching by MFG or MFG part number. Get the actual bearing number.
   / Well frig..... Blew a bearing in my mower #4
there must a bearing virus going around,just removed the deck on the john Deere L130 the bearings are shot going to take her in to have replaced.
   / Well frig..... Blew a bearing in my mower #5
Upper Bearing is part # L44649
Lower Bearing is part # L68149
Common also to trailer hubs so available at many auto parts stores.
best,
   / Well frig..... Blew a bearing in my mower #6
Carl, we're again apparently living parallel lives..;)
I'm knee deep in very same repairs. I'll bore you with crib note version of why I need replace my (recently replaced) bearings as it may save you or someone else a future headache
Took mower, tiller and trencher for repairs to a neighbor mechanic early this spring. Got the mower back in June and mowed maybe a half acre before I broke a blade. Broke off not one but two of those #%&&% chinese crap bolt extractors and between that and foul weather didn't mow for over a month (also working on trout ponds so incentive to mow was not top priority). ANyway. last week finally repaired the blade and got back to it...mowed the eight terraced rows of our orchard and as I turned down the lowest last row noticed the left spindle wobbling. This was maybe three hours of use after completely replacing all bearings!!
Turns out the KEY was not pushed down to also hold the slotted nut, which managed to spin loose, dropping the dougnut down the shaft enough to tear up the bearings....
MAKE SURE THE KEY IN THE KEYWAY IS POSITIONED FOR DOUBLE DUTY TO HOLD BOTH THE PULLY AND THE SLOTTED NUT!!!
I've decided to accept this a sign that I should quit whining, suck it up and just do my own repairs...I may capitulate again some time but for now.....
Best,
I am taking pix and will provide a write up of my experience, but does anyone have suggestions for a heavier duty bearing? I will be at napa tomorrow. My neighbor is an amazing mechanic and he was right there saying why are these standard trailer bearings?
Oh. And thus ain't easy. Glad my mechanic friend is around for hand holding
   / Well frig..... Blew a bearing in my mower #9
I have to ask, did you put any grease in the hub, and was there any grease in there when you tore it apart?
Why trailer bearings you say.
Because the mower spindle is probably a wheel hub.
So trailer bearing would apply.
You might look at the manufacturer of the bearings and see if they are Chinese.
You might try a different type of grease.
If bearings don't get moisture in them, they tend to last a long time.
   / Well frig..... Blew a bearing in my mower #10
Well I had this happen to me about a year ago and put it on an old post on here. I was pretty upset at the time but it wasn't to bad and I learned a lot about the mower deck.
Here is the thread I posted it on.
<http://www.tractorbynet.com/forums/power-trac/184220-source-mower-spindles.html>
2023 John Deere 6120E MFWD Tractor (A53342)
2023 John Deere...
2003 Ford F-350 Dump , VIN # 1FDWW36P63EC81092 (A51572)
2003 Ford F-350...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2019 TAKEUCHI TL12V2 SKID STEER (A51246)
2019 TAKEUCHI...
City of Lakeland (A51691)
City of Lakeland...
2015 Jeep Wrangler 4x4 (MPV), VIN # 1C4BJWEG5FL757630 (A51572)
2015 Jeep Wrangler...
