Welding with an alternator??
/ Welding with an alternator?? #1
montanaman
Butler PA
Tooo many to list!!
Was posting to another question and it brought up one of my own. There are a few places that sell alternators with control boxes so they can be used for stick welding. Just wondered if anyone had the know how to build something like this as the ones I've seen are pretty expensive.
I had looked at the production units a few years back and instead of good info, these places were spending a lot of effort bashing each others products so I skipped the whole idea.
So does anyone know how to make one? I know it's pretty cheap to hot rod a 10SI to gett some good amperage out of one!!
Ken
/ Welding with an alternator?? #2
Most of the time on alternators it is the DIODE pack that are the weak link. They are designed for short periods of higher amperage (after starting say) and longer periods of smaller draw, (radio/ignition ect.) in real world alternators don't supply enough power to run ALL of the accesories at once without keeping them at a high RPM with good cooling. turn on all the lights heat ect then you end up using all the alt juice and some battery juice at times especially when ideling low/slow...
addapting one or sevearal alternators to make a welder can be done, and kits are available like you said from many places. generally replacing the weak links (diodes) with larger higher amp units are part of it. some also want higher load windings... or making a welder that uses several alternators is even better.
hardest part is controlling the amperage fine enough to actually WELD controllably. that is harder... (i'll leave my thoughts out of that one due to I'm not sure what is best or easiest way or even which way works)
anyhow keep us posted if you come up with good parts ideas and or places to get them...
/ Welding with an alternator?? #4
Thanks very much folks! Lots of good info and links there. I've been on Machine Builders Network and I have to say it is an awesome site. One of those sites that makes you wish you were going to live for ever so you could have more time to build!! I guess that would still leave the problem of where to hide everything from the wife!!
I have done so much research on future projects but I'm getting smarter about knowing the ones I'll never have time or money to complete!
Ken
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A67714)
2011 MULTIQUIP...
PORTA POTTY (A67714)
1996 International 4700 (A64127)
1996 International...
2016 FORD TRANSIT CONNECT (A66091)
2016 FORD TRANSIT...
2012 INTERNATIONAL PAYSTAR 5900I (A67714)
2012 INTERNATIONAL...
