Welding Turn Table part 5
   / Welding Turn Table part 5 #1
longevity
https://youtu.be/4brH27QKLhY
In this video Rob will embark on creating a welding turn table from things found lying around his garage and around the Longevity shop. In part one he will plasma cut rim to create a base for the turning mechanism. Also Rob will go over the theory of the creation of the welding turntable and how it will work. Rob uses Longevity's Innovator 255i to plasma cut the rim. For more information on the Innovator 255i follow the link below:
Welders, Welding Equipment & Machines, Commercial Welders | Longevity-inc.com...
Portable MIG-TIG-STICK Unit
The LONGEVITY PROMTSョ 200i combines 3 welding processes in 1 machine with an impressive 200 amp MIG welder, 200 amp TIG welder, and 170 amp STICK welder.
Easy Push-Button Setup
The PROMTSョ 200i is very user friendly! All the
adjustments are properly spaced and coded which allows
for easy on-the-fly adjustments. The grouped and coded
system allows the user to see the settings quickly and
make necessary adjustments easily, allowing the welder
to more efficient in the workspace and a fine shaped arc!
Powerful, Reliable, Efficient IGBT Technology
Longevity offers cutting-edge technology in the
PROMTSョ 200i by including IGBT semiconductors inside
this unit. IGBT technology makes this unit more reliable
than other comparable units using old-fashioned
technology. By using IGBT components, LONGEVITY is
able to offer a potent welder that is lighter and more
space-efficient than its outdated counterparts.
Digital Amp and Volt Meter
By using digital meters, LONGEVITY gives the operator
instantaneous outputs which are easily read while welding.
This allows the user to dial-in their favorite settings
accurately, again, and again!
Larger Wire Spool Capacity
LONGEVITY understands the importance of time and
money. With this PROMPSョ 200i, you are able to use 11lb spools for longer welding times without having to
change the spool. This also saves you money as you are
able to buy larger spools at greater discounts. Do not
need to use that much wire? No worries. You are able to
use small 1lb rolls of wire without additional equipment!
Burn Back Control
LONGEVITY uses Burn Back Control to prevent excess
amounts of wire from sticking out by providing extra arc
time without feeding. This allows the user to make
excellent re-starts as smooth and painless as possible.
Stick With Adjustable Arc Force
With Arc Force, you are able to adjust the inductance of
the arc for either a crisp arc or soft arc with a fluid puddle.
This will allow for greater control of your welding
parameters.
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
2009 IC Corporation PB105 School Bus (A59230)
2009 IC...
Towable Chemical Applicator Sprayer (A59228)
Towable Chemical...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
