Welding Splitter Wedge, Help Please!
   / Welding Splitter Wedge, Help Please! #1
Prodirt6000
Bronze Member
A friend wants me to cut his 4 Way wedge so it is just a single. Is it ok to just use the torch?
I also need to re-weld the single wedge to the frame. Whats the best way to do this? Preheat to cherry red...then....?? Whats the best electrode to use?
Any suggestions would be great help.
I'm a pretty good welder, been schooled and all, just need some more advise for this here. Dont want the weld to break for this guy.
   / Welding Splitter Wedge, Help Please! #2
What type of steel is the wedge made of?
Wayne
I'm not exactly sure what type of steel it is. I was hoping maybe you guys would have an idea. Is there a steel that is most used for wedges?
   / Welding Splitter Wedge, Help Please! #5
I got tired of squishing home made wedges and bought three of the ones you smack with a maul and welded them one on top of the other. I used fresh 7018 at around 140 amps and they have never come loose....I'm surprised too.
   / Welding Splitter Wedge, Help Please! #6
Most wedges are standard low carbon steel, that is what mine is. We welded it on at 150 amps DC+ with 7018 rods, three passes.
James at PJ commercial products sells a hardened wedge, it costs 32 dollars an inch, so a ten inch wedge would be 320 bucks... And welding it on would require somebody who knows what they are doing. (like not me...)
Good luck
Wayne
   / Welding Splitter Wedge, Help Please! #7
I also did mine with 7018,but with my ac welder.Has held all these years no problem.Wedge is a NORTHERN TOOL ,welded to an i beam.
ALAN
   / Welding Splitter Wedge, Help Please! #8
I would weld the first pass with E6011 that is a deep penetrating rod.
Clean up the slag. I mean really get rid of the slag!
Finish it with E7018 two or three more passes. That should hold for a good long time.
   / Welding Splitter Wedge, Help Please! #9
The reason I didn't use 6011 for the root was the unknown composition of the wedges....
   / Welding Splitter Wedge, Help Please! #10
7018 is deep penetrating itself, you do want the amps cranked up with 1/8" min rod.
I like the idea of the 3 wedges stacked together, quick poor-man's fix.
UNUSED AGT YSRT14 STAND-ON SKID STEER (A51247)
UNUSED AGT YSRT14...
20314 (A51694)
20314 (A51694)
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A53472)
2004 Capacity Yard...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
