Welding rod question and help
   / Welding rod question and help #1
davel745
WV
Is there a guide for certanium welding rod?
I need to weld cracked mild steel, and cracked hardened tool steel.
How do I determine what I need? There web site is useless. Any ideas were I can get the rod? Online sales are fine.
Is there a representative that knows there stuff I can talk too? Certanium is the only stuff I know about, if there is other stuff I would appreciate any info.
Dave
   / Welding rod question and help #2
Google Eutectic welding rod. They make good stuff. Thier website should be helpful to you.
   / Welding rod question and help #3
My experience with Eutectic and Certainium goes back a long way......If you talk to professional welders you'll realize these expensive rods are all designed for either special purposes or inexperienced welders ......
Yes, they do make good products but nothing beats practice to achieve the skill to use normal everyday rods that can be purchased anywhere welding supplies are sold....
Myself, I would runaway fast from salesmen who sell this stuff.....:)
   / Welding rod question and help #4
Matching the alloy of the rod to the base material (work piece) is desirable. Recommendations are hard to make well when the alloy you are working on isn't known.
Pat
   / Welding rod question and help #6
i agree... other than prep and grind I usually don't go to great lenghts of special rods for plain mild steel. just penetration depth and size and rod type for the machine i'm using.. IE.. ac only or ac/dc...
soundguy
   / Welding rod question and help #8
soundguy
and the occasional preheat......
UNUSED CFG INDUSTRIAL QK20R EXCAVATOR (A51247)
UNUSED CFG...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A53472)
2020 Westfield MKX...
Pair of New 700/40-225 Alliance Tires with Rims (A53472)
Pair of New...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
