Welding onto the ROP
/ Welding onto the ROP #21
At Advance or Auto Zone today I seen what I'm gonna use for auxillary lighting. For around $25 they had these neat halogen utility lights that have flood and spot bean and mount via big ol' magnent! The magnent looks about 4 inches long and the width looks awful close to the width of the rops. Has a plug on the end like your cigarette lighter and makes wiring a breeze.
My question... The auxillary wire by the rops... is it switched to the lights? Always hot?
Bluegrass, Pick It Up!
/ Welding onto the ROP #22
Woodstock,
I think it makes sense. I'm thinking of adding lights to my BX. My problem is that the top of my head is higher than the top of the ROPS. Another location I have thought of is just above the indicator lights.
Patrick (the tall one)
/ Welding onto the ROP #23
Boman, I'm not sure on your tractor, but suspect it's just like the B2710; that wire is NOT connected to the lights in any way, but is a separately fused circuit (so your auxiliary lights need their own switch) that is hot any time the key is turned on.
Bird
/ Welding onto the ROP #24
jim: if it was me i would just take and mig weld the brackets on. i don't think there is enough heat to worry about. although ! once u modify the rops in ANY way u loose all product liability. but i would not loose any sleep over it.
/ Welding onto the ROP #25
Mike,
I would avoid the option of mounting half way up the ROPs... If you turn around to back up, you would be totally blinded! Not fun!
Billboe
/ Welding onto the ROP #26
Depending on what kind of work you want to do at night, lower wattage lights (25w to 35w) can give adequate light without heat or blinding problems. Also, one facing front and one back works well, you can look back without a light in your face.
/ Welding onto the ROP #28
Woodstock, my rear work lights are mounted on the sides near the top. I too used U-bolts to attach them. It is, to me, the perfect solution...easy on, easy off and no worries about weakening the ROPS.
/ Welding onto the ROP #29
Jim, I can tell you for a fact that you will not harm in anyway the ROP by welding light barckets on it. I have been a certified pipe welder for over 40yrs so have burnt a rod or two. The material it is constructed of is A36 steel. It doesn't get its strength from the grade of the steel but rather the shape of the steel. I have modified goverment owned equipment with no problem getting approval on anything after giving them the specs and strengths of the steel.I would however keep the heat at a minimum and use the smallest rod possible. I think you have received alot of good info from the men that have replied to your thread here and thats one reason I love sitting and reading them, good luck and bright light.
/ Welding onto the ROP #31
Welcome to TBN! You responded to an 11 year old post, so you probably won't get much of a response. :)
Glad he did though as the issue of how to add things to a ROPS comes up all the time. People warn against drilling which may be overly cautious but it is nice to consider welding on a tab or something similar for a light fixture. Good option and I appreciate Rodiron's rationale and experience.
2012 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2012 FORD F150...
2005 MACK CV713 MIXER TRUCK (A67714)
2005 MACK CV713...
2016 MACK GRANITE(INOPERABLE) (A67714)
2016 MACK...
PAIR OF FRAC TANK STANDS (A68842)
PAIR OF FRAC TANK...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2017 PETERBILT 579 (A67714)
2017 PETERBILT 579...
