Welding on tractor advice
/ Welding on tractor advice #21
I would consider the path that the current must flow when welding on a piece of equipment. If the current must flow through a bearing or even a movable joint the there could be microscopic arcing that may or may not cause premature failure. People that are new to tractors and/or new to welding may never have really given much thought to all of this and it never hurts to hash it around a bit. I have learned so much from the wisdom of the TBN braintrust and for that I am always grateful. :D
/ Welding on tractor advice #22
I usually disconnect the batteries when I'm going to be doing extensive work, but won't bother for lots of quick little jobs - especially when the batteries are 40 feet away at the other end of the truck / machine.
The only stuff I seriously worry about is the early 90's stuff with engine / transmission ECU's that where very susceptible to getting "zapped" by a welder -- it really sucks to do a 5 minute little weld repair and then realize that NOT unhooking the ECU will now cost hundreds of dollars to have it reprogrammed along with a potential towing bill since the unit won't move because of it...many times it take longer to access / unhook the ECU, then the repair will take, but you gotta do it..... luckily, I have never zapped one myself (knock on wood).
/ Welding on tractor advice #23
i have welded on trucks and tractors without a problem .some of the time when i am welding on equipment hooked on tractors they are running.i have not had a problem yet.maybe i am just lucky.
2013 WINSTON AP22024AL-DC EQUIPMENT TRAILER (A66091)
2013 WINSTON...
2011 FORD CROWN VICTORIA CAR (A66091)
2011 FORD CROWN...
2024 CATERPILLAR 299D3 XE SKID STEER (A65056)
2024 CATERPILLAR...
1994 KENWORTH T600 (A67714)
1994 KENWORTH T600...
2016 Mobility Ventures MV-1 Passenger Van (A66736)
2016 Mobility...
2022 Kubota SVL65-2 (A64911)
2022 Kubota...
