Welding on empty drums
   / Welding on empty drums #2
My Dad said he saw a guy in the shop that wanted to make a burn barrel out of a 55 gallon sealed drum. As soon as he burned thru the end with the torch, Kaboom and he was dead. I think he said the drum has some kind of glue in it. Who knows what the glue solvent was, but something flammable. All it takes is just the fumes left in the barrel.
   / Welding on empty drums #3
That would have never happened if he used an Everlast welding machine! ;)
   / Welding on empty drums #4
If he had used a 120 volt MIG it would have never burn thru, because he would never have gotten any penetration.:laughing: I know I should never had said that but the devil made me do it.. :D
   / Welding on empty drums #5
Saw that happen at a place I worked 35 years ago. Mechanic in the shop took a empty 55 gal alchol drum (we burned alcohol in salamander heaters in the back of our delivery trucks in winter) and laid in on its side. He straddled the drum and started to cut the top out with the torch and kaboom! The end blew out and sent him flying out the shop door in flames. He had some serious burns and all the windows in the shop were blown out. Spent over a month at home recouperating before he came back to work. Company stopped using the alcohol heaters after that, we installed hot water baseboard in the trucks which was tied into the engine cooling system. We delivered plants and flowers year round to flower shops up and down the east coast.
   / Welding on empty drums #6
I take exception to the making fun about this type of situation. This sort of thing can happen whether using a 120v mig or a $20,000 three phase machine. I had a buddy get severely burnt from a metal 5 gal bucket blowing up. He wasnt even welding on the bucket, but using it for a seat while welding on something else. For my buddy, this was certainly a life changing event. I just pray that nobody reading this tread has a similar life changing, or life ending, experience.
   / Welding on empty drums #7
I don't think anyone was intentionally trying to make fun about it. NOBODY should ever weld or cut on barrel or have one in close proximity unless they know for sure what has been in it and/or it has been properly cleaned so it is not a dangerous hazard.
   / Welding on empty drums #8
Last time I wanted some holes in a barrel I used a pointed pickax. I have also shot holes in them. Of course the label on the ones I got from the feedstore said apple juice concentrate.
   / Welding on empty drums #9
I always use a jig saw. Used cold chisel & hammer for a long time but jig saw is quicker.
   / Welding on empty drums #10
An air chisel does a great job for this task. You will definitely want to use hearing protection.
KSI Conveyor (A51039)
2020 Peterbilt 389 Tri-Axle Sleeper Cab Truck Tractor (A49461)
2020 Peterbilt 389...
12.7 LITER DETROIT GENERATOR SKID (A50854)
12.7 LITER DETROIT...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2019 CATERPILLAR D3K2 XL CRAWLER DOZER (A51242)
2019 CATERPILLAR...
EVERYTHING SOLD AS-IS WHERE IS!! (A50774)
EVERYTHING SOLD...
