Welding on a vehicle/machine with electronics...
   / Welding on a vehicle/machine with electronics... #11
twice, worked for a couple of companies that were all about time rather than proper procedure. Luckily it came out of their pocket not mine :)
It seems that the best action to take is to remove implement from tractor and find a different way to raise mower.
Thanks to all for advice. :thumbsup: It will be heeded.
That seems like a definite trend in the making and not a one time fluke.
Glad to hear that you weren't on the hook for their poor decisions. :)
   / Welding on a vehicle/machine with electronics... #14
We have some computerized equipment at work. Once the mechanic needed to do some welding on one piece. We always do the lockout tagout procedures and this includes turning of the battery masterswitch and locking with tag. The switch was off but not locked out while he was looking at the machine and when he got ready to weld, he turned the battery switch on and the proceeded with the lock and tag out. When he got done makeing the repairs, you guessed it, nothing would work. The welding shorted out a bunch of circuit boards, $10,000 worth. It was a very costly lesson. A few weeks later, the same mechanic had to weld on another piece of equipment that was parked right behind the first piece he had screwed up. This is railroad equipment setting on metal rails. The first piece of equipment was actualy running when he struck an arc on the second piece, Bam! the first peice shuts off and another $10grand down the drain. Lots of mad folks when I had to call it in.
On pieces of Equipment with the new JD engines, we unplug the ECM before the welding leads are dropped off the truck. Welders pop them like popcorn.
I vote for unhooking the battery when welding and if its a new model with electronics, unplug the control module too if you can.
   / Welding on a vehicle/machine with electronics... #15
When I was a professional welder, I learned from experience to:
1) Seperate the part if you can, if not then;
2) Disconnect the battery
3) Disconnect the alternator-for some reason welding on a vehicle with the alternator connected can result in alternator death or worse damage to elsewhere.
HMM!
Normally when this topic comes up I chime in that I do it all the time, weld on trucks and tractors with out isolating the electrical components. With no apparent problems.
But maybe I have to rethink that position, I did weld on my brand new trucks trailer hitch, with out disconnecting the battery, that was in 08, but this year the alternator went and when they replaced the alternator, they found out the ECM was bad too. Now that was 3 years ago, but the truck only has 26,000 miles on it so that is way to early for either of those problems to have occurred.
Luckily I had 3 weeks left on an extended service contract, cause the ECM was $1,800. alone just for the part. Didn't really associate this with the welding, but since you mentioned the alternator, it made me think.
I wonder if there could be such a delayed reaction ???
JB
   / Welding on a vehicle/machine with electronics... #16
that long? not very likely... should have been noticeable.. kinda like a fuse. works or don't.. immediately..
muddstopper,
OUCH! What is the old adage, don't kill the messenger.
Twice in a row to the same poor guy. Would have thought he'd have been SO gun shy about doing any welding around that 1st machine. :ashamed:
   / Welding on a vehicle/machine with electronics... #18
Besides the obvious of having a fire extinguisher nearby; I'll place a welding blanket over areas of the vehicle I don't want sparks to get at.
   / Welding on a vehicle/machine with electronics... #19
It depends!
The welding current has to flow through something, and that current produces a strong magnetic field. That magnetic field can couple energy into other circuits (similar to the way a transformer works) and, if you are unlucky, you might couple enough energy into an electronic circuit to destroy a semiconductor.
Whether the battery is connected or not has little to do with it. You can frazzle an electronic device with an EMP (electro-magnetic pulse) even if it is not turned on.
If you don't want to remove all the electronics, the best thing to do is keep the ground clamp as close as possible to the point where you are welding, and make sure it is really well connected to the metal. What you want to do is give the return current the easiest, and shortest, path back to the welder. If you are really finnicky, keep the ground lead and the electrode leads as close together as possible. You might even put them in a lazy twist if you can.
If the ground connection is poor, and you attach it at the opposite end of the vehicle from where you are welding, be prepared for trouble.
Tiny Tym,
I like the lead twist idea. They use twisting of conductors inside Ethernet cable to eliminate cross talk. Certainly makes sense that it would work on a ramped up scale.
2012 C&M TRAILER 14 T/A ENCLOSED CARGO TRAILER (A55745)
2012 C&M TRAILER...
2005 PETERBILT 379 DAYCAB WINCH TRUCK (INOPERABLE) (A53843)
2005 PETERBILT 379...
2003 INTERSTATE 70SDGN ROTO-KING DETACH TRAILER (A52706)
2003 INTERSTATE...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
20ft Shipping Container (A54865)
20ft Shipping...
2017 FORD F-150 XLT CREW CAB TRUCK (A52706)
2017 FORD F-150...
