Welding on a hydraulic cylinder
   / Welding on a hydraulic cylinder #1
allen in texas
Platinum Member
Levelland, TX
Kubota Grand L 5740, loaded R1's w/640 lbs cast weight, 854 loader
I "MAY" have to build my own hydraulic top link. (long story) If I do, is it necessary to disassemble the cylinder when welding the end on the cylinder, you know in consideration of seals and such.
I would think that I could just scope out the rod when I weld the end on it.
Where can I get a DPCV (double pilot check valve).
I really hope I don't have to do this. Still waiting on a call or email.
anyone ever welded on a cylinder?
   / Welding on a hydraulic cylinder #2
The cylinder "should" be disassembled when welding on it, but you can get away with moving the seals away from the weld area (if you are welding on the base end) and covering with wet rags.
DPOCV's (double pilot operated check valves) are available, but not the small ones like CCM uses. CCM has sold them alone, you can search threads from user 3RRL (Rob), he added some to the stabilizer's on his backhoe.
The Surplus Center sells two stock sized HTL's with the DPOCV's also...
"The Surplus Center sells two stock sized HTL's with the DPOCV's also..."
I need a HTL with 11 or 12 inches of travel and an over all length extended of 38 inches.
I use ALL of that travel when working my boxblade and now that I've traded tractors, my HTL is too short. :(
The attached pic is my temporary mod to my quick hitch that will work until I can get a longer top link.
Ugly but it works
   / Welding on a hydraulic cylinder #4
KennyD's right, only if you are welding on the base end is it ok to weld......best to take it apart and don't overweld it....the barrel will distort and all kinds of problems will happen........
I figure the email I'm waiting on will take care of my problem.
HA! I just looked at my picture and you can see the tag on that brand new tire on that brand new tractor. :)
I am still obligated to post pics of the tractor on the Kubota owning and operating forum.
   / Welding on a hydraulic cylinder #7
Ah, I see where you're welding......adding on the hyd rod or cyl base is OK to weld without taking apart, just keep it cool ......May be easier to add a piece of steel between the base plate and rear clevis (more meat to weld to) vs adding to the hyd rod.....:)
I want to add 6 inches to the base of the cylinder, not to the rod. Simply move the cylinder out farther from the tractor. (further?)
Perhaps a pipe just under the OD of the barrel welded to the end of the barrel THEN the rear clevis welded on
like the crude drawing in the picture
   / Welding on a hydraulic cylinder #9
I welded mine without troubles, I pulled the rod as far out to get the rubbers away from the weld area. It was winter so I burried it with snow and welded and welded.just go slow.. dont over heat.
   / Welding on a hydraulic cylinder #10
That's a perfect way to do it....(can also be a slug of solid stock also)
2019 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2019 Ram 1500...
2024 CFMoto Cforce 600 4x4 ATV (A51694)
2024 CFMoto Cforce...
CAT RM-300 (A53843)
CAT RM-300 (A53843)
2016 Freightliner Gradall D152 Truck Mounted Excav (A53117)
2016 Freightliner...
2025 CFG Industrial M-AG (A50123)
2025 CFG...
2008 Isuzu NPR-HD Truck, VIN # JALC4W16287003622 (A53422)
2008 Isuzu NPR-HD...
