welding helmets
   / welding helmets #41
Henro,
That is what I thought, you might get flashed just a bit but no damage. I can't even see the flash, guess my brain is a bit slower than some /forums/images/graemlins/smile.gif
Ben
   / welding helmets #42
<font color="blue"> The only reason I am taking issue with your statement is because I think it is important that accurate info be posted.
I don't believe your statement is correct, and I doubt it will be possible for any of us to cite a reputable reference that agrees that harm is done to one's eyes during the transition period from light to dark...
</font>
Bill I think your post indicated that I was making up the information that I presented here at the TBN site and that clearly was not the case. I gave you the name of the publication as well as the page number where it was printed. I didn't say that you would go blind using an auto-darkening helmet, I merely quoted the information as it appears in the Welder's Handbook manual. Seems we have some conflicting information.
And just for the record I do weld myself with an auto-darkening helmet so I do believe in them.
   / welding helmets #43
<font color="blue"> Bill I think your post indicated that I was making up the information that I presented here at the TBN site and that clearly was not the case. </font>
PineRidge, I centainly wished not to offend. I hope I did not, and I certainly hope that I did not imply that you were making anything up. If I remember correctly, you made a statement and that stagement was to the best of my knowledge not correct.
Nothing more than that. I just figured you were stating an opinion. All of our opinions are based on something, sometimes scientific fact, sometime faith what someone else says, and so on.
Anyway, if the Welder's Handbook says eye damage is likely to occur during the transition from light to dark, it most likely is in error.
Now there is no doubt you cited a reputable reference. I wonder how old your edition is and if newer editions of that handbook states the same thing, or if it has been changed?
It would be interesting to post that paragraph from the Welder's Handbook on the hobart site, or another weldor's forum and see what the response would be to it there.
I do sincerely hope that you do not think I was attacking you personally or anything like that. Like other members who have been around here a while, I consider you one of my TBN friends. I was simply trying to respond to a statement that was contray to what I know and believe to be the case.
I certainly would like to read that page and will PM you my email address... /forums/images/graemlins/smile.gif
   / welding helmets #44
</font><font color="blue" class="small">( Now there is no doubt you cited a reputable reference. I wonder how old your edition is and if newer editions of that handbook states the same thing, or if it has been changed? )</font>
Perhaps it was based on the performance of auto-dark helmets when they were in their infancy ....
One thing that annoys me about my Harbor Freight auto-dark unit is that it seems to turn itself off (go completely dark) a little quick - happens at the most annoying times. It seems to be a predefined time period from when the unit was turned on (and not measured from the time an arc was last struck.) The other thing that is annoying is both the on/off switch and the shade control are inside the helmet - which makes it a pain to adjust or turn back on when you have the hood down and gloves on.
   / welding helmets #45
Rswyan,
Harbor freight has sold several different models, my harbor freight autodark helmet has the shade control on the outside and is easially adjustable after the arc is struck. It is identical to the cheap Hobart that TSC sells inside and out except for the Hobart sticker. Just got a new HF flier in the paper has one with outside shade adjustment in it for 59.99, good till 12/26.
Ben
   / welding helmets #46
Regarding the subject line Welding Helmets ...
Um...why do you want to weld on your helmets ? /forums/images/graemlins/confused.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/blush.gif
Oh, I get it. Sorry /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / welding helmets #47
</font><font color="blue" class="small">( Um...why do you want to weld on your helmets ?
Oh, I get it. Sorry /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif )</font>
No you're not. You enjoy making us suffer.
Cliff
   / welding helmets #48
slowrev,
Thanks - I just got that flier in the mail myself. That helmet was the one I originally looked at - unfortunately when I was ready to buy it wasn't the one on sale. For the amount of welding that I do I'll probably just hold where I'm at until this one gives up the ghost and then replace it with one I like better.
   / welding helmets #49
I have a Jackson helmet. I have a cheap helmet as well. They both work fine for stick and wire feed welding.
I find that the cheap helmet doesn't work as well for TIG welding, especially high amperage AC welding for aluminum. My eyes get fatigued in the cheap helmet. The Jackson helmet has better adjustments for shading, and also better adjustments for the sensitivity of the helmet.
When using a TIG torch, you sometimes get a shadow from the gas cup that hides the direct arc from the light sensor on the helmet. The reflected light from the arc often times won't trigger the cheap helmet right away. It is bright as ****. My good helmet has a total of 8 light sensors that surround the LCD. I think it does a better job catching the initial start. The cheap helmet appears to only have 2 sensors. I also think, subjective observation, that the Jackson gets darker than the cheap helmet.
My opinion: The cheap ones are probably fine for many uses. However, AC welding generates a much brighter arc, and requires a higher quality system. For me, I think I got what I paid for in both cases. The Jackson helment was $190 a couple years ago. The cheapo helmet was $70.
   / welding helmets #50
OK, I've followed this trend and you guys sold me.
Just bid on an ANSI approuved on EBay and won it at $36.00 plus he ships to Canada reasonably via USPS which is important for us canucks as the brokerage fee is only $5.00 as compared to about $40 with other carriers.
Now I am anxious to get it and try it.
Think I'll go build myself a light bulb 'stick oven'.
   / welding helmets #51
HF 91214 (FLAME!) /forums/images/graemlins/cool.gif and 91212 are on sale online right now for $50 each
I have # 46092 (also $49 online right now) and like it even though its only 1/20000 sec /forums/images/graemlins/tongue.gif. It came with a spare clear splatter guard.
Here's the description of 91214:
Superior auto-darkening lens for arc, MIG and TIG welding.
Large viewing lens: 3-7/8'' x 1-5/8''
1/25,000 second switching speed (clear to dark state)
Variable shade control--shades #9 to #13
High/low light sensitivity adjustment
UV/IR protection
Automatic power on/off with adjustable delay time
High impact-resistant polyamide nylon construction
Backup rechargeable battery
Full face coverage with ratcheting headband
Meets ANSI Z87.1-1989 standards
Weight: 0.8 lbs.
   / welding helmets #52
</font><font color="blue" class="small">( Think I'll go build myself a light bulb 'stick oven'.)</font>
Been there. Done that.
The best thing for that I've found is an small upright freezer. Disconnect the motor and direct wire the light. Replace the light bulb with a twenty five watt severe service bulb and you'll have your rod toasty anytime you want it. But, and this but is of Barr proportions, you will go through bulbs. And the rough service ones last longest.
   / welding helmets #53
Installed a compact flourescent bulb like these bulbs in our rod oven. Seems to work just as well and it's been going for 11 months straight now.
   / welding helmets #54
This may be the time to actually benefit from the 130V bulbs which some rough service bulbs are. Very inefficient in terms of lumen output but the heavier filament does tend to last longer.
   / welding helmets #55
Hey Rat:
Long time no talk to.
I comandeered my wifes old toaster oven. I can get about 15 pounds of rod in there at a time.
The added benefit is that I use it to normalize parts I machine from tool steel after I harden them.
I also warm sandwiches and it keeps my coffee hot in the cup when it's sitting on top.
   / welding helmets #56
<font color="blue">I comandeered my wifes old toaster oven. I can get about 15 pounds of rod in there at a time.
</font>
Daryl is that what they mean when they use the phrase multi-tasking? /forums/images/graemlins/smile.gif
TANK MANIFOLD (A55745)
2015 GMC Sierra 1500 SLT Crew Cab Pickup Truck (A59230)
2015 GMC Sierra...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
Informational Lot - Shipping (A61306)
Informational Lot...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
