Welding guard on tractor with HF flux wire welder
   / Welding guard on tractor with HF flux wire welder #1
NTG
Roanoke, AL
2016 New Holland Workmaster 33
I have one of the cheap HF flux wire welders and I've only welded a couple things with it with decent results I thought. Now I want to weld a piece of expanded metal on the ROPS bar on my tractor to keep from getting my brains busted out. My questions are, where should I connect my welder's ground cable and do I need to be concerned about shorting out the electrical system on my tractor if I connect something wrong? Tractor is a 2016 NH Workmaster 33.
   / Welding guard on tractor with HF flux wire welder #2
It wouldn't hurt to remove the battery ground, or both for the heck of it. I've always made sure I have a good, close ground to my work, but on these very recent year, electronic's dependant trucks & tractors, I'd play it safe.
That sounds like a good idea. :) I think there are some lugs sticking out up there on the ROPS, maybe for mounting a canopy or something. Think I could just grind the paint off one of those and attach my ground clamp there?
   / Welding guard on tractor with HF flux wire welder #4
Certainly!
I've never disconnected a battery on any vehicle ever, in 40 years welding. But I ALWAYS put my ground close to the item being welded, and ON THE ITEM not going across a bolted joint etc. Not to say you shouldn't disconnect the battery. Just that I've NEVER HEARD a verifiable problem from welding on a vehicle. But it sure makes sense to put the ground close to the weld.
   / Welding guard on tractor with HF flux wire welder #5
Unbolt the guard and bring it to your welding table. use blue 242 LocTite when bolting it back on.
   / Welding guard on tractor with HF flux wire welder #6
If you haven't done much welding yet this is a very good idea. It will be much easier welding with the ROPS laying horizontally.
   / Welding guard on tractor with HF flux wire welder #7
You should consider making a frame that is removable. The expanded metal can be welded to the frame and the frame bolted to the ROPS.
   / Welding guard on tractor with HF flux wire welder #8
That's what I'd do. Drill & tap the ROPS then you don't burn your ROPS paint. Also the whole thing can be made on the bench, painted too.
Or maybe your ROPS is foldable? Fold it down it might be easier to work on, horizontal welds not vertical. For the ground sometimes its easier and more reliable to grind a little un-seen spot for a vise-grip and attach your ground to the vise grip.
   / Welding guard on tractor with HF flux wire welder #9
If your ROPS is foldable, you might be better off using a frame and some sort of quick-disconnect fasteners. Otherwise, you might find yourself unable to fold it because objects going into what is now free space...won't be.
(Also consider that the objects may not be there now, but you might want them in the future. I want to put a toolbox on my tractor that will be inside the open space of my ROPS when folded. I'd definitely use a frame and QD bolts/wingnuts/etc.)
   / Welding guard on tractor with HF flux wire welder #10
You might even use some square u-bolts to attach the guard to the ROPS if desired.
2014 FORREST RIVER SALEM TRAVEL TRAILER (A50854)
2014 FORREST RIVER...
2022 CATERPILLAR 306CR EXCAVATOR (A51242)
2022 CATERPILLAR...
UNUSED Grey Metal Roof Panels (A50860)
UNUSED Grey Metal...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2013 TRAVIS BODY & TRAILER, INC. ALUMINUM BELLY DUMP (A50854)
2013 TRAVIS BODY &...
2016 Nissan Altima 2.5 Sedan (A48082)
2016 Nissan Altima...
