Welding gas ripoff
   / Welding gas ripoff #1
orezok
Elite Member
Mojave Desert, CA
Kubota B7800
I took my 80CF C25 bottle for a refill at Praxair. After I left I noticed that there was a sticker stating 69CF and the invoice said 70CF.
I guess Praxair can't get 80 CF in an 80CF bottle any more!
   / Welding gas ripoff #2
Was it filled to the proper psi? If so, it was properly filled.
   / Welding gas ripoff #4
The local dealer I use just swaps cylinders out. You pay a flat fee so there's nothing on the invoice to tell you how much you got. It's common practice to leave about 300 psi in a tank to avoid any air/ moisture getting into it. However I usually push it until empty because I'm in the middle of a project trying to finish.
Propane tanks for BBQ grills have a limiter built into them so you can no longer drain them empty. But some of the national companies like Amerigas are not filling the tanks up all the way. As far as I know that's only being done with propane.
   / Welding gas ripoff #5
I think that is a proper fill for that cylinder
   / Welding gas ripoff #6
Just purely a guess. I wonder if it was 69 to fill, in other words, the tank wasn't quite empty.
   / Welding gas ripoff #8
I am guessing that was full.. My brand new to me 150 cf tank only read 2000PSI when i got it from praxaire..
   / Welding gas ripoff #9
Yes, in general barbeque propane tank "swap out" is rip off any more. They only fill them 75% (16 lb) "to save you money":confused:
Ken
1264 (A50490)
1264 (A50490)
2020 John Deere 9470RX Tractor (A53342)
2020 John Deere...
2009 Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
2009 Caterpillar...
KUBOTA B7510 TRACTOR (A51247)
KUBOTA B7510...
2021 Ford Explorer (A51694)
2021 Ford Explorer...
JOHN DEERE 54D LOT NUMBER 146 (A53084)
JOHN DEERE 54D LOT...
