Welding BH frame
   / Welding BH frame #1
fcamillieri
Bronze Member
Chester, NH
CK20HST
I'm having a hard time keeping the bolts tight. Has anyone welded the braces on their BH? I can't think of a reason not to. I imagine they are bolted for easier shipping.
Frank
   / Welding BH frame #2
Frank
Why not use some locktite?
   / Welding BH frame #3
I have not welded them but I had the same problem. I even twisted bolts in half trying to tighten them up. I would up getting really heavy grade bolts and used a MAJOR johnson bar with a pipe on it and loc-tite. No problems since.
   / Welding BH frame #4
Frank
I welded mine several years ago.
No problems since.
   / Welding BH frame #5
I second the idea of locktite, the stuff has worked well for me on other applications.
Joel
   / Welding BH frame #6
Frank
I welded mine in about a month ago as I could not keep them tight and I even used Lock Tight Extra Strengh and I finally took the welder to them and now they don't move and snap around like they did., It is a lot smoother on the machine too... why they bolt them on I do not know.
The Fox 1940
   / Welding BH frame
Thanks for the info. I think I'll weld it mainly because I'm lazy and it's the easy thing to do.
Frank
   / Welding BH frame #8
I DRILLED 3/16 HOLES THROUGH THE NUTS AND BOLTS AND USED COTTER PINES. I THOUGHT I WAS THE ONLY ONE THIS HAPPENED TO.:eek:
   / Welding BH frame #9
Would you need to cut the welds to remove the hoe? or is this a subframe that remains on the tractor and does not affect implement usage?
My hoe has frame that bolts to the tractor and then the hoe has a 4 point mount and comes off of the tractor with a lever, the frame that remains has no impact on implement usage.
I'm guessing they are bolted on because not every tractor comes with the sub-frame if you are not using a hoe?
Joel
   / Welding BH frame #10
The bolts attach the BH to the subframe. The subframe has no bolts attaching to the tractor.
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2007 Nissan Armada Multipurpose Vehicle (MPV) (A51694)
2007 Nissan Armada...
2020 KUBOTA RTV...
2239 (A51244)
2239 (A51244)
Guard Rail Pieces (A51692)
Guard Rail Pieces...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
