Welding and Parkinsons
   / Welding and Parkinsons #31
What I got was that you felt personally attacked my words, which may have a deeper meaning.
Thousand of people each year are killed in car accidents. Perhaps we should all stop driving.
Millions of people each year contract viruses and bacteria through air-borne particles. Perhaps we should stop breathing. John
   / Welding and Parkinsons #32
Unfortunately, you can't really rely on old data for things like that. Lots of people die from misdiagnosis today, or die with a undiagnosed condition. Prior to all the developments in medical science the situation would have been much worse and the data wholly unreliable. Plus, people tended to die much younger which further distorts comparisons (for example, if you were going to die at 60 from cancer, but died from a mill accident at 45, the cancer rate appears lower).
Similarly, analysing a patient population and finding that one group (for example welders) is present more often in a statistically significant proportion tells you absolutely nothing about whether or not the disease is caused by welding. This is because even 'random' data has patterns in it if you look hard enough. This is also why they define target populations before doing drug tests, because you can, for example, find that 'all left handed tuba players with advanced lung cancer benefitted from the drug'.
Perhaps other studies which could find that exposure to manganese in other contexts (various other industries, ground water, and so on). If they also show an association, then you * may * be on to something.
In order to prove causation, you need a model and experimental (or other) proof that the model is valid. For example, you say manganese causes Parkinsons because ..., and you feed a bunch of mice or whatever, manganese and you see what happens.
Of course, none of this has anything to do with the question at hand. Class action suits are not about what caused the problem (or most significantly, in this case assuming there is a cause/effect, should or could the welding industry have known this).
Now, everything I have ever read about MIG/TIG or stick welding (including books written 50 years ago) say: wear gloves, wear a full face mask, and work in a well ventilated environment. Not that that should count for anything ...
   / Welding and Parkinsons #33
My 70 yr old uncle has Parkinsons and has never welded a day in his life. He was a typesetter by trade until he retired about 5 or 6 years ago.
Janet Reno has Parkinsons. I doubt if she has done any welding either.
   / Welding and Parkinsons #34
</font><font color="blue" class="small">( My 70 yr old uncle has Parkinsons and has never welded a day in his life. )</font>
My mother, 76 years of age has suffered from Parkinson's for about the last 3-4 years. No one else anywhere in our family has had it, although there is eveidence that it can be genetically transmitted. Mom never welded.
There is a lot of evidence that manganese toxicity can destroy the dompamine producing cells and lead to Parkinson's, but there aren't enough empirical studies on welding/parkinson's to make any judgements.
   / Welding and Parkinsons #35
It's also about 100% probability that living is a primary cause of death.
   / Welding and Parkinsons #36
</font><font color="blue" class="small">( It's also about 100% probability that living is a primary cause of death. )</font>
100% correct! J
   / Welding and Parkinsons #37
<font color="blue"> My 70 yr old uncle has Parkinsons and has never welded a day in his life. </font>
And the relevance is? /forums/images/graemlins/confused.gif
   / Welding and Parkinsons #38
</font><font color="blue" class="small">( <font color="blue"> And the relevance is? /forums/images/graemlins/confused.gif </font>
)</font>
The presuposition that welding contributes to Parkinsons disease is anecdotal at best, and until there is sufficient statistical evidence to support that position care should be taken but panic should not set in.
   / Welding and Parkinsons #39
72% of all statistics are meaningless.
   / Welding and Parkinsons #40
And the other 27% don't hold water either.......how about 1% fac and 99% fiction (real or imagined).
Mayrath 6x21 Truck Auger (A49339)
Mayrath 6x21 Truck...
Feed Bunk (A49339)
Feed Bunk (A49339)
2014 UTILITY 53X102 DRY VAN TRAILER (A45678)
2014 UTILITY...
2014 Ford Escape SE SUV (A48082)
2014 Ford Escape...
2006 JLG 600A 60ft Articulating Boom Lift (A46683)
2006 JLG 600A 60ft...
2018 Bobcat T590 Compact Track Loader Skid Steer (A46683)
2018 Bobcat T590...
