A slight departure, but here's an oldie but goodie.....
A guy jumped out of a perfectly good airplane with a parachute strapped to his back. At the predetermined time, he pulled the rip cord, nothing happened. He pulled the backup-chute chord, nothing happened.
As he fell while holding 2 rip chords, he stared at the ground, wondering where he will meet his demise. Then he noticed a dot getting larger, it was getting larger logarithmically faster than the good earth. Very quickly, that dot grew to reveal that it was a man approaching him in mid air!
Thinking quickly, the parachutist yelled to the man; Hey buddy, do you know anything about parachutes?!?! The fast approaching man with his pants on fire yelled back; NO, do you know anything about welding hydraulic tanks?!?!
I have read where people used dry ice to repair gas tanks. Haven't tried it myself.
I once used natural gas when brazing some refrigerant lines to prevent oxidation and scale inside. As someone already said, you just have to push out the oxygen.
I'd have to think about it some before I'd try it on the Frame/ Hyd tank. It should work fine, it just sounds scary.
If you decide to use something to clean off the oil film, DO NOT use any chlorinated cleaner, like chlorinated brake cleaner. Even when it looks to be completely dried off the metal, enough remains to create phosgene gas when the heat of welding hits it and is enough to really choke you up if you get a whiff of it. A crack might hold quite a bit of it and would be much worse.
are you sure it was natural gas and not nitrogen gas. I'm sure the results would be quite different.
