I dont have a loy of wleding experience, any tips are greatly appreciated.
My Massey Fersuson deisel backhoe developed a hairline crack at a weld that connects the vertical hollow FEL / Engine brace frame, to the horizontal hollow frame that goes to the rear end area. These combine to form the hydraulic reservoir for the implements. The hyd fluid is leaking out at the rate of a quart a week while sitting and making a real mess. I have an arc welder and wanted to give it a shot repairing depending on some knowledgable answers.
1. Which rod should I use? I have some "farmer" rods, 6014? I believe
2. I would drain the oil to a level below the crack first, is there a fire or exposive danger? How should I prepare the area?
3. Do I need to disconnect the battery or other items?
3. Is there a better solution than welding?
Thanks
Thanks
