Welder Recommendations
   / Welder Recommendations #1
wayne48
Bronze Member
Vermont
MF 1433v
Having acquired all the power and hand tools that I could want ( at least for the time being ), I've got the itch to buy a welder. Can anyone give me advice on what I should look for? Arc or Ox-Acy? Make and Models? Approximate cost?
I'm looking for something that I could use for general repair/fabrication work on my place. Probably wouldn't work with anything bigger than quarter inch angle steel.
Bear in mind that I'm a total novice when it comes to welders.
Any advice, pointers or recommendaations would be greatly appreciated.
   / Welder Recommendations #2
If you plans are to weld mostly angle irons and steel plate then I would get started with a 225 amp arc welder like the Miller 225 ac/dc welder. Some models only come AC but it may be a little easier to do some jobs with AC/DC machine. This would be a good way to get started learning to weld. You could also go with a MIG machine in the 110v style and use flux core wire for welding lighter material. Miller also make a nice 220v unit that will weld flux core but come with a regulator so you can weld with a shielding gas. There a many ways to go and lots to learn.
Spending a little time taking a night class at a tech school will give you lots of information and a chance to try all the different ways of welding.
Although you can purchase a welder at many local stores like Home Depot, TSC, Northern Tool, etc I would stop in to a real welding supply/gas company and talk to them about your needs and they will be able to help you with a machine. My supplier, (Prax Air) will even set up the machine and let you demo it before you purchase.
Charles
   / Welder Recommendations #3
Hi wayne48, Like many TBNers who find this site looking for tractor information you found this site to contain ALL information even remotely related to tractors. There are many knowledgeable people who visit this site regularly ready and willing to share their knowledge and expertise in this tractor loving community. Many people who never had any expectations of being a welder find themselves needing this skill for repair or fabrication of the tractor or implements or buildings for the tractor. I sure wish TBN would have a welding section.
Now to answer you question. A lot of people, like myself, just want to jump in and get-er-done. You did not mention your welding experience. I consider myself a novice after a semester of welding class at the local community college, (compared to W-Harv). I will always recommend a class or local college because there is a lot to learn and many ways to do welding improperly. The added benefit is that you will be taught to weld on all sorts of welders and materials. At the end of the class you will know which one works best FOR YOU and your projects. For me after the class I chose a MIG welder (Miller Passport) for the farm. The reasons were 110 and 220v and generator friendly. MIG is easier than stick for a novice /forums/images/graemlins/grin.gif, it is very portable and light and can work off my golf cart and I can use gas (co2 paintball size in welder case) or flux core.
Good luck in your welding endeavors!
   / Welder Recommendations #4
I consider myself a hobby welder. I learned 20+ years ago in college using a torch and welding rod.
I now have a Miller Passport and love it (same model as TX Don). Its on the expensive side of welders but it is dual voltage (110v and 220v) and it is portable (its in a self contained suitcase). It uses compressed CO2 as shielding gas and the bottle fits inside the case so you can literally carry the whole unit to wherever you want to go. For modest duty welding it is a nice unit. Miller has a DVI unit that is also nice, less portable, but dual voltage so you can weld with either 110 or 220 it also has the type of capacity you are looking for. Hobart makes similar units that are probably the same quality as Miller.
I totally agree with FL Cracker. Go to a real welding store and talk to them. Welding class would be a great thing to do too.
   / Welder Recommendations #5
I was a certified welder for years... fun to do but tough to make a living at.
I'd recommend a AC/DC welder, that can put out at least 100 amps with a 30%duty cycle.
Practice makes perfect.... and practice is the name of the game. Anyone can weld... but getting the right penetration and the right rod is the key to success.
Here is some keys:
1) prepare... clean is good...do not weld over rust and paint and remove all your slag.
2) it's better to be a bit hot (amps higher) than cold... cold lap welds break. No more than 3 passes on the same area and over lap the initial bead 1/2 way.
3) for DC welding use even number rods... like 6018 or 7018. AC welders need odd number rods like 6013. You can use any number rod with a DC welder, not so for AC welders. the higher the number the more tensile strength. A good all round rod is 7018.
4) Stick welding is harder to learn but easier to do. Anyone who's been doing a job for al long time knows what I mean. Play with different heats (amps)
5)Get a good mask and gloves. By "cheater lenses" if you need reading glasses (like me). DO NOT buy gloves that are thick, you loose your sense of touch.
6) learn to bench weld first, (looking down) then side ways... then up hill, then down hill.
If you practice a lot you'll do fine.
To all you Gentlemen that responded to my post, Thank You!
It's always great to hear from people who have been there, done that.
I think I will start by taking a class as many of you advised and then go from there.
Thanks again.
Have a Saffe and Happy New Year. /forums/images/graemlins/laugh.gif
   / Welder Recommendations #7
If you are typically going to be working with 1/4" and below, I would reccomend a MIG with flux core wire. The flux core wire stores well so you don't need an oven like you will with conventional welding rod. It will provide good results for the beginner right from the start without too much practice. I have shown several people how to use it dand they are always amazed at how easy it is. Far easier than stick. I would also reccomend lessons or a welding class to get your weld quality up there quicker.
I would reccomend a machine that can be expanded later. Some manufacturers sell a flux-core only machines where others such as Lincoln and Miller have entry level machines that come set up for flux core but can be upgraded with "gas' kits to make use of shielding gas to weld very thin sheet as well as Stainless and Aluminum.
I have a Lincoln Weldpack 100 with a gas kit that I have been using for many years. I bought it at Cosco. It is 110VAC powered and cost around $300 new. You can find the current version of the weldpack in most home depot stores. They also offer a 220V version. They are not very heavy to move around and do not take up much space. I keep mine in a cabinet under my workbench when not in use. I have taken mine to work several times as it was far easier to move around the ship than the onboard welding equipment. On my last ship, the DC's liked mine so much, they went and bought one for their shop as it could handle the majority of the remote repairs and new installations that they typically need to do and it didn't take them an hour to set it up for a job.
One of the best things about these small MIGs is that they will go down to fairly thin sheet metal. I have used mine to patch holes and weld in replacement panels in auto body sheet metal and it is excellent in fabricating exhaust systems. They are also great for assembly work. Hold part A against part B. Point the gun where the 2 parts meet and squeeze the trigger with a little flick of the wrist and you have a tack weld.
If I had a complaint, it would be the duty cycle limitations of the smaller machines such as the weldpack when working on larger material. I recently built a fork bucket for my loader and had to manage my assembly(weld for a bit, go cut out a new part, go back and weld for a bit) to keep up a steady work pace without exceeding the welders duty cycle and having to wait for the welder to cool down. Normal for me would be to cut, fit/assemble then weld. Doing it this way would sometimes leave me with a lot of breaktime during the welding portion waiting on the welder to cool. If you think ahead, it is not a real problem. For a machine with a higher dutycycle, you will pay substantially more money.
I may at some point get a stick welder but as yet I have not needed one. And even if I did have one, I would still grab for the MIG most of the time, even if only to do the tack welding/assembly work.
   / Welder Recommendations #8
Good call - take the class and you'll likely get to play with a variety of machines. I was very happy with the experience (though it's tough some times when you want to just go out, buy the toy and start rippin'). My needs are similar to yours - I built a set of 4 horse stalls, welded all of the vertical bars. Other that that I mainly plink around in the 1/4" and under category, so MIG was the right setup for me. I ended up with a Millermatic DVI - it does 110 and 230 and has a decent duty cycle and some of the nicer features of their high end units.
Enjoy!
LAXPatrick
   / Welder Recommendations #9
All the power and hand tools I could want? Hmmmmmm..... I don't think I understand. I do use my oxy acet. torches more than either of my welders. That would be, and was my first purchace for my shop (assuming you have an air compressor). Depending on budget and projects, the welders would be next on my list. Stick welders can be had reasonably cheap and would be pretty versatile too.
   / Welder Recommendations #10
I bought a Lincoln Pro 135 from Lowes. It's a 110 volt MIG welder for welding up to 1/4" plate. The 110 Volt hook up is so handy. Did run the flux core for a while, but I got spoiled on the gas welding and been hooked ever since. What a great machine. Never thought I would use it so often. No regrets using it in my garge, its a perfect machine.
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A51572)
2007 International...
2009 Lee-Boy 8510HD Conveyer Feed paver (A52748)
2009 Lee-Boy...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A52748)
2004 Capacity Yard...
2004 PETERBILT 385 (A52472)
2004 PETERBILT 385...
2016 TANKKO 130BBL VAC TRAILER (A52472)
2016 TANKKO 130BBL...
