Welded VS Bolted hydraulic cylinder?
   / Welded VS Bolted hydraulic cylinder? #1
unioncreek
southeastern WA
1949 Farmall M
I'm looking at a hydraulic cylinder for the tilt on my loader and have noticed that the price varies between the welded and bolted one's. Is there a difference in performance and quality of the two and can the welded ones be repaired as easily as the bolted together one's.
Thanks,
Bobg
   / Welded VS Bolted hydraulic cylinder? #2
Bolted hydraulic cylinders is an American thing. Here in Europe they dont make them that way at all, and the odd one to be seen here, is the same Chinese stuff that you guys get retailed by Harbour Freight.
You can allways unscrew the caps of welded cylinders because they arent fully welded: only the end cap is welded on, the front part (from which the piston sticks out) is screwed into the tube.
Off course it depends on how its built, but as a rule of thumb i think cylinders with welded or screwed caps are more sturdy than those that hang together with some threaded rods: Especially on long rods, they need a lot of pre-tension because the full length can stretch out, and lead to leakage if stretched further than the seals can make up for.
It might be cheaper to manufacture, because the DOM tube only has to be chopped to length and deburred, not requiring the extra welding and thread machining, which are extra steps in the manufacturing process.
In high end applications, i dont think you'll see any cylinders held together with threaded rods.
   / Welded VS Bolted hydraulic cylinder? #3
Very well said from a different perspective than we on this side of the pond have.
The tie rod cylinders are a little easier to rebuild.
   / Welded VS Bolted hydraulic cylinder? #4
It seems acceptable in the USA... but over here, if the company i work, showed a payloader with tie rod cylinders on a fair, that would be a total embarrassment... :D
   / Welded VS Bolted hydraulic cylinder? #5
Over here as long as it's cheap it's okay. And if it doesn't work, it's not an embarrassment, it's an experiment.
BTW, I don't agree with it, but it's what the American public has asked for. Now, they got it.
   / Welded VS Bolted hydraulic cylinder? #7
In the USA machinery needs to look HD and be functional. In Europe machinery needs to have Beauty-Smooth lines-and be functional.
Buy the cheaper cylinder...90% are made in China.
EV59
   / Welded VS Bolted hydraulic cylinder? #8
Even though the American culture has strong roots in several European cultures, there is, and allways will be, a difference in many little things...
And: I'd rather put it the way that the European market requires the looks/appearance of sophisticated engineering, rather than just the looks of smooth design lines.... ;) Lets put it this way: no two dogs are alike (read my signature) :D
   / Welded VS Bolted hydraulic cylinder? #9
Thanks,
Bobg
Bob,
If you get the tie-rod cylinder, you will probably never notice a difference on performance. The welded one is definately higher quality and will stand up to more abuse and last longer. However, for your application, the tie-rod will work just fine.
Andy
   / Welded VS Bolted hydraulic cylinder? #10
I agree with that..
compact tractors would probably not go over 150 bar... construction applications go over 300 bar.. If i had to build something for a customer, i'd use "welded" cylinders because it looks better... if it was for myself, in this application i'd probably use whatever is cheapest.. :)
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
FRONTIER AV50H LOT NUMBER 114 (A53084)
FRONTIER AV50H LOT...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2025 New/Unused LandHero 1 in Air Impact Wrench (A51573)
2025 New/Unused...
1996 Fiat Allis FG 65C Motorgrader (A51573)
1996 Fiat Allis FG...
