Welded Cylinder, dissasemble, and weld crosstube onto?
   / Welded Cylinder, dissasemble, and weld crosstube onto? #1
cruzer
I have two cylinders at work that are no longer needed - would like to use them for a loader, but they do not have mounts on the end of the body, only the side like they were mounted flat to a plate. Can i remove the guts (piston rods etc) and weld on a cross tube to the bottom of the cylinder?
thanks
   / Welded Cylinder, dissasemble, and weld crosstube onto? #2
Yes you can. Or, you could probably get by just extending the rod out to get the piston seals away from the heat and weld it that way. Wrapping wet rags around the tube will help draw the heat away too.
Kim
Great! Thanks for the response! I thought that was the case but wanted to make sure.
Cruzer
   / Welded Cylinder, dissasemble, and weld crosstube onto? #4
Kim
What Kim said...
But also you need to be carful you don't get it to hot and warp/distort the cylinder tube.
   / Welded Cylinder, dissasemble, and weld crosstube onto? #5
You might try this little trick. Remove the piston assembly. Plug the base end port, and fill the tube with water. Then sit the base end, vertical on the cross tube or whatever, and weld . The water will absorb the heat.
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2015 Toyota Camry Sedan (A51694)
2015 Toyota Camry...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2025 Epic Electric Cart (A51694)
2025 Epic Electric...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
