Weld Repair on my LS Tractor Bucket
   / Weld Repair on my LS Tractor Bucket #1
goddom
Flat Rock, MI
LS G3038H
I was starting to get some cracks in the bucket just above the reinforcement on the sides above the blade. So I ground them down and chased them with weld then I used my plasma cutter to make some more reinforcements for the side of the bucket and welded them on. You can see what I did in the video below. For some reason my initial welds were pretty terrible, but when I welded on the reinforcements I got into my stride and I am pretty happy with them.
How To - Tractor Bucket Repair - YouTube
   / Weld Repair on my LS Tractor Bucket #2
Looks good . Maybe look into a tooth bar , helps save the bucket and allows much easier digging.
Thanks for the suggestion! I think I will!
   / Weld Repair on my LS Tractor Bucket #4
Good repair, I better go out and take a look at my bucket (same as yours)!
Let me know what you find! I would be curious to see if its just me being hard on it! I have moved a lot of gravel with mine and when plowing a couple of my neighbors driveways have an uneven section and I have hit it pretty hard with the bucket - so I am sure that didn't help anything.
   / Weld Repair on my LS Tractor Bucket #6
Buckets get abused and need periodic maintenance or rebuilding if you use them a lot. Nothing out of the ordinary there, don't worry. You're doing fine just fixing it before it peels open like a sardine can. Or grinding giant void spaces.
   / Weld Repair on my LS Tractor Bucket #7
I do a lot of back dragging with my bucket on a 1/4 mile gravel drive. Added some 1/8" plate under the bucket, and it has protected it very well.
You're right...they do get abused, especially by me !
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2021 MACDON C3812 LOT NUMBER 34 (A53084)
2021 MACDON C3812...
2010 Ford Escape Hybrid SUV (A51694)
2010 Ford Escape...
2002 Fleetwood Expedition 36ft Class A Motorhome (A51694)
2002 Fleetwood...
Hay Spear for Tractor (A51573)
Hay Spear for...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
