Weld or Clamp
/ Weld or Clamp #1
PaPaGus
Western MA
Kioti CK 25
Given all the attention the KL130 loader received, would anyone chance welding a bracket to the cross torque tube for grapple lines? :confused:
Just afraid if I do, they will come out with a clamp around package like the KL120.
Bruce
/ Weld or Clamp #2
Always bolt or clamp. Welding is final without a mess, besides the metalurgical changes in the structural member being welded to. You can adjust a bolt or clamp but not a weld. Never weld on a structual member. Good luck on your endeavor, Ron.
/ Weld or Clamp #3
Don't weld on the actual tube. The removable access plate is fair game though. You could do a cool bulkhead fitting through the plate. Are you dealing with the old 130 or the new one? The new one has a huge cover plate that is of heavy sheet and would work great.
/ Weld or Clamp
I am dealing with the old 2006 :( style. I may be able to run a piece of flat stock from the cover area over to the side and bend it up and around. Thats a good thought Joe, Thanks for the reply.
Bruce
/ Weld or Clamp #5
Bruce,
A lot of loaders have the metal pipes retained by clamps that use 1/4" bolts tapped into the arms. Drill and tap holes for a couple of 1/4" x 28 bolts and bolt the bracket to the cross member. It would make a neat clean install.
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
KUBOTA KX71-3 EXCAVATOR (A65053)
KUBOTA KX71-3...
2018 INTERNATIONAL 4300 S/A 4X2 26FT NON CDL BOX TRUCK (A59914)
2018 INTERNATIONAL...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
2016 John Deere 470G Hydraulic Excavator (A64194)
2016 John Deere...
