Weld or Clamp
   / Weld or Clamp #1
PaPaGus
Western MA
Kioti CK 25
Given all the attention the KL130 loader received, would anyone chance welding a bracket to the cross torque tube for grapple lines? :confused:
Just afraid if I do, they will come out with a clamp around package like the KL120.
Bruce
   / Weld or Clamp #2
Always bolt or clamp. Welding is final without a mess, besides the metalurgical changes in the structural member being welded to. You can adjust a bolt or clamp but not a weld. Never weld on a structual member. Good luck on your endeavor, Ron.
   / Weld or Clamp #3
Don't weld on the actual tube. The removable access plate is fair game though. You could do a cool bulkhead fitting through the plate. Are you dealing with the old 130 or the new one? The new one has a huge cover plate that is of heavy sheet and would work great.
   / Weld or Clamp
I am dealing with the old 2006 :( style. I may be able to run a piece of flat stock from the cover area over to the side and bend it up and around. Thats a good thought Joe, Thanks for the reply.
Bruce
   / Weld or Clamp #5
Bruce,
A lot of loaders have the metal pipes retained by clamps that use 1/4" bolts tapped into the arms. Drill and tap holes for a couple of 1/4" x 28 bolts and bolt the bracket to the cross member. It would make a neat clean install.
2017 Ford Explorer (A50324)
2017 Ford Explorer...
Yanmar YM170D Tractor (A50514)
Yanmar YM170D...
2012 VANGUARD 53FT DRY VAN TRAILER (A52141)
2012 VANGUARD 53FT...
John Deere 6410 Loader Tractor (A50514)
John Deere 6410...
Excavator Mulching Head (A50774)
Excavator Mulching...
White 2-55 Loader Tractor (A50514)
White 2-55 Loader...
