Weld on teeth for TLB front bucket
   / Weld on teeth for TLB front bucket #1
slan
Nova Scotia, Canada
Kubota L3240 HST
I want to put some teeth on my front bucket of my Ford 655 and was wondering, Do I just get some weld on teeth and weld then directly to the cutting edge?
My bucket doesn't have a bolt on cutting edge but when I got it (6 years ago) I put on a new arrowhead weld on cutting edge on it. Its about have worn now so do I just weld right to the cutting edge?
Pictures would help if anyone has any.
Thanks guys.....;)
   / Weld on teeth for TLB front bucket #2
Do you ever use your FEL for anything that would be hendered by the teeth? Some things would not be possible with permanent teeth - ie scraping a paved driveway..
They make bolt on tooth bars that are easily removed (2 bolts) when you dont need it.. Markham is one of the more popular mfg..
good luck
brian
   / Weld on teeth for TLB front bucket #3
What's that 655 weigh? 21-22K?
I don't think I've seen a bolt-on that would stand-up to that size machine...
I'd ONLY weld onto the cutting edge. When it goes and you'll need a new one - wouldn't want to have to cut the teeth off the main bucket.
'Course a bolt-on could be welded and it would make the spacing and the level of the teeth more uniform and less likely to shift with heat, etc. Just never seen one before.
Or get another bucket. Can't back-drag for beans with those teeth! :D
AKfish
Thanks guys.
Yup, its a beast for sure, about 105hp and about 20,000 lbs
Since I got my small kubota I dont need it for finish work anymore so once the teeth were on I would never need to take them off. If I needed to backdrag I could use the heal edge of the bucket.
I just need a bit more digging power when loading from a topsoil or sandstone piles after they have sat for a few years. I pretty much have to break them apart with the hoe first unless I do the rookie thing and ram into them:eek:
So I guess the best approach would be to weld them on to the cutting edge.
The bucket is 1.5YD and 7' wide. What do you think, 12" or 8" apart?
By the time they are worn out the machine will be a bunch of parts or someone else will own it. The thing has been the best piece of equipment I have ever owned. And wow, it a Ford!:D
Bought it out of a snowbank about 8 years ago with 4500hrs for $11,000 delivered and now have 8400hrs with only a rebuilt fuel injection pump as repairs go.:)
Its not worth splitting it and replacing the clutch packs or pins/bushings so i will be driving it into the ground.:(
Thanks guys.
Thanks guys.
I went to the Hitachi dealer today and picked up 7 weld on shanks, teeth, and pins.
One way trip here I come.:cool:
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A54607)
2015 GREAT DANE...
2015 Dodge Charger Sedan (A51694)
2015 Dodge Charger...
2014 CATERPILLAR 289D SKID STEER (A52706)
2014 CATERPILLAR...
One pallet of miscellaneous items (A53117)
One pallet of...
