Weird squeaking from engine
   / Weird squeaking from engine #1
Nitric
02 Farm pro 2430
So I have a 04 farmpro tractor. As of late I hear this high pitched squeak as it runs. I have absolutely no idea where it could be coming from. It's driving me nuts since I can't pin point it's location. Any help appreciated
30hp 3cyl diesel
   / Weird squeaking from engine #2
30hp 3cyl diesel
Interesting. I had the same issue with my TY395 three cylinder diesel. Mine was more like a chirping sound though.
   / Weird squeaking from engine #3
Does the frequency change with the engine RPM?
A quick and easy trick is to take the fan belt loose from the crank pulley as part of the process of elimination.
In ancient times we used to put belt dressing on squeaking belts. Don't know if you can even buy it anymore....
You can also use a long screwdriver as a mechanics stethoscope. Hold the handle against your head in front of an ear and place the tip on various components such as front and rear alternator housings. That will transmit the sound to your inner ear and make it easy to isolate.
This is definitely my issue. The sound is exactly the same. Did you ever find what the cause was?
   / Weird squeaking from engine #5
Yes. The rockers, shaft, and push rods weren't getting enough oil. I don't know which engine you have but the Jiang Dong engine (letters JD in a diamond on left side of block) has a brass metering orifice under the first rocker shaft stand-off. Mine was plugged. Pull your rocker shaft and inspect everything for abnormal wear.
Thank you
   / Weird squeaking from engine #7
Yes, you can still get it. Last year I got some for my 25 year old Harbor Freight drill press. Ruined the belts in short order.
   / Weird squeaking from engine #8
Mechanics stethoscope or WD-40 should be safe enough to spray to locate.
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A52128)
Quick Attach Skid...
2017 Dodge Grand Caravan (A50324)
2017 Dodge Grand...
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
Champion C80 B (A50322)
Champion C80 B...
John Deere 825i Gator (A50514)
John Deere 825i...
