Weird engine noise.
/ Weird engine noise. #1
BertZegers
South-West Ontario
Kubota L2900, Zetor 8011, Kubota KX41Excavator, John Deere 4400 Combine, Case 1816C skidsteer
I have a diesel tractor with a high pitched noise coming from the timing area of the engine. The timing is with gears. The noise can be heard clearly if the oil fill cap is removed. The oil fill cap is on the timing cover.
I am afraid it might be a main crankshaft bearing or a timing gear bearing on the way out.
I am not sure what to do, what do you tractor guys think?
The tractor is a Zetor 8011 the engine year is 1976 type 8001.
2015 GMC Sierra 1500 Crew Cab Pickup Truck (A61573)
2015 GMC Sierra...
(2) 15 Gal Sprayers, 25 Gal Sprayer, Honda Pressure Washer, Wheel Barrel (A64119)
(2) 15 Gal...
2015 Hyundai Genesis 3.8 Coupe (A61574)
2015 Hyundai...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
2019 Ram ProMaster 2500 Cargo Van (A61573)
2019 Ram ProMaster...
UNUSED WOLVERINE HYD GRAPPLE BUCKET (A64281)
UNUSED WOLVERINE...
