Weird backhoe removal 3 point setup and behavior
/ Weird backhoe removal 3 point setup and behavior #1
rbstern
Platinum Member
GA
LS MT225E, Yanmar 2210
I took the LB1100 backhoe off my MT225 (XG3025) for the first time yesterday. When I got it dismounted and unhooked the two hydralic leads, I found myself with a strange situation: The two connectors on the tractor, which should be reconnected to form the "loop" for the hydrualic circuit both had female quick couplers. The backhoe had two male connectors. No way to loop the tractor lines without some type of adapter hose with two male ends. I went back to my original docs/bag from the dealer to make sure they hadn't included anything like that. No such luck.
Looked through the manuals. No guidance whatsoever. Watched a couple of Youtube videos on disconnecdting an LS backhoe, not model specific, but they always seem to loop the disconnected hydraulic lines.
Add more weirdness: With the loop not connected, my 3 point lift didn't work, but the FEL still worked. Hmmm. And the 3 point has no resistance: I can move it up and down by hand. Checked the 3 point lowering speed valve under the seat. Tried it all ways, left it in the middle.
Next, I swapped the male and female connectors on one set of the tractor/backhoe leads, so I would have male/female on the backhoe, and male/female on the tractor. After that I looped the tractor hydraulic lead. Same result: FEL works, 3 point does not.
I have a call into the dealer now, waiting for the mechanic to come on duty to talk it thru with him. Figured I would check here to see if anyone has an answer to this mystery.
/ Weird backhoe removal 3 point setup and behavior #2
Don't run the tractor with the lines disconnected!
The reason why the loader works with the lines disconnected is because the fluid has no where to go and the relief valve on the loader valve is opening and dumping the excess pressure to the tank, therefore is not feeding the circuit beyond the loader valve.
Running like this for long period of time will cause the fluid to get really hot and damaging stuff like the pump.
Looks like the dealer messed up the quick disconnects for the backhoe. It's an easy fix or you can just get the dealer to fix that for you.
I already did the connector swap and it did not change the result. Did not run the tractor for more than a minute or so with the lines disconnected.
/ Weird backhoe removal 3 point setup and behavior #4
Yes but you need to find the right lines.
Because one of the lines will be the pressure line while the other will be the return/tank line.
Pressure line of the tractor, goes to pressure side on the backhoe valve. Tank line of the backhoe valve goes to tank line on the tractor.
There is only one way to hook it up, based on hose lengths.
/ Weird backhoe removal 3 point setup and behavior #6
Are you using the rear remotes that came with the machine? There should be a lever to turn that remote on and off!
/ Weird backhoe removal 3 point setup and behavior #7
Make sure all remote valves are centered.
The backhoe option added a third SCV to my tractor with a detented valve. When the backhoe is off the tractor and I forget to center that valve, it behaves as yours does, but it also makes a louder hydraulic howl than normal that reminds me to check the valves.
/ Weird backhoe removal 3 point setup and behavior #8
So on the LS tractors, the backhoe runs off a remote valve?
I thought it ran like the Kubota tractors, where you actually split the circuit and add the backhoe in the middle. Therefore my posts above.
No rear remotes on my machine. One line from the under-step block that splits out hyrdaulics to the loader, and a tapped fitting on the left rear axle housing.
Mystery solved. Either the factory or the dealer set this up differently than expected.
There's another quick disconnect on the other end of the line that feeds the backhoe, near the hydraulic block under the right footboard; it's attached to a line coming from the loader control valve assembly. There's an unused, male quick disconnect on the front of the block near the footboard. To change from backhoe to rear 3pt lift, I have to uncouple that line, and plug the line coming from the loader valve assembly to the unused male connector on the block.
Less convenient than looping the cable at the rear.
Nothing in the documentation, and no discussion of that issue when I took delivery of the tractor. In fact, I think I was told the opposite...that I should loop the feed at the back of the tractor.
/ Weird backhoe removal 3 point setup and behavior #11
Some do like mine as stated above, the smaller or more bare bones tractors use the loop method. Since we didn’t know all the details about OPs machine, I thought it was worth mentioning.
My tractor has three sets of SCVs, with one being detented to run the backhoe or anything else that needs constant flow.
/ Weird backhoe removal 3 point setup and behavior #12
My XG3025 (now the MT225) has the detent valve/ rear remote. Both the BH hoses plug into the remote valves at the rear. Both BH hoses are male. If you plug them in wrong, it just makes the BH controls opposite.... I can either switch the hoses to opposite ports or switch the detent valve to the opposite direction. Sounds like your dealer "cheaped out" on how he hooked up the BH plumbing.
If the detent valve is 'activated' without anything connected, it definitely "howls" louder, reminding me center the valve.
My 3 point works with or without the BH attached.
Hopefully your dealer gives you an easier way to make the "change-over".
/ Weird backhoe removal 3 point setup and behavior #13
And you are a life saver. Dealer was at a loss and was waiting on LS regional contact to call him back. This process is not listed ANYWHERE in LS manual or on the Internet. Glad I found this. I will need to call the dealer and educate them in case someone else has this issue. Thanks again.
/ Weird backhoe removal 3 point setup and behavior #14
One thing I learned about my MT225E tractor is that the backhoe is plumbed at the end of the power line that feeds the 3 point. So, when you disconnect the backhoe, you have to connect the lines together so the fluid can flow through the system and back to the reservoir.
If you don't connect them, the pressure relief valve will operate and probably your pump will bog down the motor due to high pressure operation.
/ Weird backhoe removal 3 point setup and behavior #15
BUT... do you have rear remotes? The setups are different if rear remotes are added. If no remotes, then that circuit has to be completed as you stated.
/ Weird backhoe removal 3 point setup and behavior #16
This sounds very similar to my kioti lk3054xs TLB.
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
Wooden Rocking Chair (A61569)
Wooden Rocking...
New/Unused Landhonor 50 Ton Capacity Hydraulic Shop Press (A61166)
New/Unused...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Chevrolet Silverado 3500 Crew Cab Utility Flatbed Truck (A60352)
2014 Chevrolet...
SDlanch SDLGC80 (A60462)
SDlanch SDLGC80...
