Weight of pallet forks for the 300cx loader
   / Weight of pallet forks for the 300cx loader #1
tomd999
Platinum Member
Viva Manchvegas!
'10 3320 cab
Hi,
I'm in the process of purchasing my next tractor, 3520 w/300cx. The dealer priced a set of skid steer forks which is incorrect because I dont want QA plates. That being said, after seeing the weight of the skidsteer forks, over 450 Lbs, I was wondering:
What are the lightest forks that will work with a 300cx capacity?
Tom
   / Weight of pallet forks for the 300cx loader #2
I made some out of 3 inch Channel that slip on over my bucket, works good enough to move cement around and way about 40 pounds
   / Weight of pallet forks for the 300cx loader #3
I think my Deere forks weigh about the same as the bucket. The regular attach and not the skid steer QA. I sure wouldn't want to be with my forks. Use them as much or more than the bucket. Adapted these for use on the iMatch as well with some additional fabrication.
   / Weight of pallet forks for the 300cx loader #5
The JD forks that are made for the 300cx are part number AP13F. They come in 42 inch or 48 inch long rails, and have a weight of 360 or 375 Lbs. respectively. The load rating is 3750, which is above the loading lifting limits. They connect to the 300cx loader with no modification, just take the 2 pins off and switch it out.
   / Weight of pallet forks for the 300cx loader #6
Also if you want fixed rail pallet forks the part number is AP12F. Same specs. except 20 pounds heavier.
Fixed rail (AP12F) $972.00
Floating rail (AP13F) $1078.00
   / Weight of pallet forks for the 300cx loader #7
Kennyd has it right:
These: Artillian Pallet Forks for John Deere Tractor Loaders
Much lighter which means the additional weight saved goes to more lift capacity.
   / Weight of pallet forks for the 300cx loader #8
We have the Artillian pallet forks for the 2305 and 2520. Works well on either tractor, takes a little time to get used too. Well worth the money!
Hi,
My only concern with the Artillian forks is that is no "fence" or backstop to help keep a load on the pallet from sliding to the rear onto the tractor. Do they make a fence kit for them?
Tom
   / Weight of pallet forks for the 300cx loader #10
you would want to talk to Chris on that. I have a place i can get some steele and fab my own fence or guard. On vaca in two weeks and that will be one of the first projects. For the most part Chris has done ALL of the foot work on the frame and the forks.... the rest is up to each individual to fab to each persons needs.... his set up is right around 220# and fabbing a guard wouldnt be more than 45# maybe??? For your 3 series it would be nothing to lift.:thumbsup::thumbsup::thumbsup:
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A53472)
NEW 2022 Load...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
Wright Sentar (A50120)
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2003 JOHN DEERE 350D OFF ROAD DUMP (A51246)
2003 JOHN DEERE...
