weight of loader
   / weight of loader #1
Coolnslo
Texas Hill Country
Mahindra 4500
Hi, I am new to this forum and have only recently returned to using a tractor after many years. Have learned a lot by searching the forum, but still have a few unanswered questions. One thing I can't find is the weight of my loader. I have a 4500 (2006) with the ML260 made by Buhler. Seems like this would be easy to find, but have checked the paperwork, Buhler's internet site, and Mahindra 24/7 care with no luck. I think this is important to know to help determine tire pressure and what type trailer is needed to haul the tractor. Anyone know the total weight of the loader and mounting hardware? Thanks for any replies.
   / weight of loader #2
according to my personal notes I have the weight on a ML260 as 1850# on a KMW loader.....I however do not have any weights on the Buhler loaders. I would assume it would be pretty close but I'm not positive.
edit: I emailed Buhler because I like to have the weights on hand as well and they said it is 1825#.
   / weight of loader #3
Here are the rest of the weights I have in my notes for other Mahindra models in case anyone else is curious.
....................................................(KMW)....(Buhler)
Model..... Mahindra...........................Weight....Weight
ML102.....1815 HST..........................590 #
ML104.... 2015 G & HST.....................585 #
ML105.... 2415 G & HST.....................666 #
ML106.... 2615 G & HST.....................695 #
ML110.... 3015 HST...........................800 #
ML111.... 2815 HST / 3215 G & HST.....860 #
ML112.... 3510 / 4110.......................1150 #
ML230.... 3525.................................1300 #...1425#
ML245.... 4530 4WD..........................1560 #
ML250.... 5525 / 6025.........................na.......1865#
ML260.... 45/55/60/6500 2WD.............1850 #...1825#
ML265.... 45/55/60/6500 4WD.............1860 #
ML266.... 5530 / 6030 4WD.................na
ML255.... 5520 2WD & 4WD.................1640 #
ML270.... 6520 2WD / 7520 2WD..........2020 #
ML275.... 6520 4WD / 7520 4WD..........2100 #
ML114.... 4510 CAB ...........................1180 #
ML170.... 7010 CAB ...........................2100 #
   / weight of loader
I didn't think of emailing them, but thanks for your help and the info Red River.
   / weight of loader #5
Thanks for info RedRiver!
I have a 4530 with the ML245 loader. Does the 1560 lbs. include the bucket?
If not, do you have the weight for a Mahindra 72" bucket?
Thanks again,
Mud
   / weight of loader #6
Yes it does. However all the weights posted on the bigger loaders are for the pin on bucket. If you have the SKC package then you need to add about 100#.
   / weight of loader #7
Thanks Jeremy!
My ML245 has the skid-steer attachment. So, with bucket included, my loader weighs 1660lbs?
Thanks again,
Mud
   / weight of loader #8
MUDONTHETIRES said:
Thanks Jeremy!
Thanks again,
That is actually the shipping weight on a pallet, but that should be close enough for government work!
Mud
I must say that the chart he posted looks strangely familiar. Also, the 266 is almost identical in weight to the 265. The only change was a modification to the mounting kit.
   / weight of loader #9
Jeremy you might have been the one to send me a list with some of those weights but I can't remember. (edit: nevermind, just found the sheet Mahindra faxed me)
I wish Mahindra would publish this spec in their brochures, it's extrememly helpful when trying to figure out what size trailer you need to haul a certain unit with the FEL.
   / weight of loader #10
Yeah... I sent the sheet to Mahindra some time back since I get calls on this all the time. The have obviously modified it to include loaders I don't build. The biggest issue is that until we start production and package the loader we don't know what it weighs and this is long after the manual is finished... I do agree however that they should publish that kind of thing.
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
2025 GPS Trailer (A56858)
2025 GPS Trailer...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A56436)
2023 Kubota U48-5...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2017 John Deere 1025R Tractor - 626 Engine Hours (A56436)
2017 John Deere...
Pintle Hitch Triple Axle Trailer - NO TITLE (A59814)
Pintle Hitch...
