Loader Weight of 4110 with 112 fel and loaded rear tires
   / Weight of 4110 with 112 fel and loaded rear tires #2
I've wondered this ever since I bought mine 9 years ago and just never was handy to have it weighed. I used to haul mine all over the place when doing commercial work for a few years with it but just never worked-out to be around a scale when loaded. I already knew exactly what my trailer weighed too, would have been easy to check it if I had had the chance. I always guessed - 1) bare tractor was advertised around 4500 lb. if I remember right. 2) I guessed around 1500 lb. for the complete FEL, mounting brackets & braces etc. I could be way off on that estimate but don't think I am. 3) I have right at 55 gal. of methanol/water mix good to -10 F in each rear tire. That translates roughly to 440 lbs. of ballast each so that would add 880 lbs. to the total. Oh yea, almost forgot - my canopy must weigh 150 lbs. by itself !!! Mine is a steel one and I've had it off quite a few times for various reasons - what a bear to do by yourself.
This all totals 7030 lbs. 99 1/2% of the time I have some sort of implement on back - my boxblade stays on when not using another one and my boxblade is pretty lightweight - maybe 350 lbs. if I'm lucky. I really like the weight of my tractor - it's a little bulldozer and has a good center of gravity, travels good on the slopes for me. Considering R4's aren't the best for plowing, I can bury my 2 bottom plow pretty deep and go right along as well as my subsoiler works well too. It would be hard to find a similar tractor with as much psi on the ground, I think. I can just imagine the traction potential of my tractor if it were outfitted with some aggressive R1's for plowing & such.
   / Weight of 4110 with 112 fel and loaded rear tires #3
Tractor, loader, and loaded rear tires about 6100 6200 lbs
STEEL HEADACHE RACK (A52708)
STEEL HEADACHE...
2007 NEW HOLLAND B95 BACKHOE (A52709)
2007 NEW HOLLAND...
Killbros 260 Seed Conveyor (A56435)
Killbros 260 Seed...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
Volvo A40D Off Road Dump Truck (A56435)
Volvo A40D Off...
