Weight Limit For LT 2138
   / Weight Limit For LT 2138 #1
RCT
Bronze Member
Raleigh, NC
Cub Cadet 2138
I was wondering what the towing capacity of my LT 2138 was. Someone said 2500 lbs which I find hard to beleive with the tractor only weighing 600-700 lbs. Also, does the new style 2500 series bumper fit the 2138, I am not really impressed with the one it has on it?
   / Weight Limit For LT 2138 #2
towing with with the ability too stop with brake, 1/2 the weight of tractor.so if tractor weights 600# the max would be no more than 300#.and that might be pushing it.
I am sure it is not 2500 lbs, but 300 seems way low. If it can pull a 17 cube cart rated at 1500 lbs, I would think it would at least be that much.
   / Weight Limit For LT 2138 #4
I think I saw that it is 300 lb tongue weight and total 1500 lb. On flat with good traction you can probably pull alot, but stopping might be a bit harder.:D
18-1 gallon jugs pure Anti-freeze (A53117)
18-1 gallon jugs...
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A53421)
Caterpillar...
2008 CATERPILLAR 725 OFF ROAD WATER TRUCK (A51406)
2008 CATERPILLAR...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
iDrive TDS-2010H...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
