weight distribution choice for a 7K dump trailer & factory F-150 hitch
   / weight distribution choice for a 7K dump trailer & factory F-150 hitch #1
nikdfish
Person Co. NC
John Deere 3038E & 1025R FILB
The factory tow hitch on our 2008 Ford F-150 needs weight distribution (WD) for tongue weight (TW) > 500 lb. and/or towing > 5000 lb. With WD, it is rated for 1000 lb. TW & 10,000 lb. towed. We have stayed under the WD requirement limit with our 7k aluminum car hauler when moving our small tractors, but recently bought a 7K dual axle dump trailer & now want to add weight distribution to handle it's fully loaded weight potential. With an additional set of brackets, we can also increase the car hauler capacity.
Empty tongue weight on the dumper is 384 lb. & the unloaded weight is about 2200 lb. I want to accommodate a full load approaching 7000 lb. when moving gravel/top soil. I am looking at the Curt 17001 and Curt 17002 round bar weight distribution kits as a couple of economical (~ $210) possibilities. The 17001 has a tongue weight range of 600 - 800 lb w/8000 lb towed max, the 17002 has a tongue weight range of 800 - l000 lb. w/10,000 towed max (matching the factory hitch max WD limits).
I am leaning toward the 17002 as the top end TW seems more appropriate with the potential TW of 15% x 7000 lb being 1000 lb. I have not actually loaded the trailer to a max load & measured the TW (because that would be beyond the factory limits without WD) so I really don't know what it will be. I expect there will be numerous occasions when I am using the dump trailer with a tongue weight only modestly over the 500 lb. limit, i.e. in the 500 - 600 lb range, like when carrying lighter materials like cut timber, etc. but still need to have WD in place. Should I go for the higher limit, just in case, even though those times will be few & far between?
Nick
   / weight distribution choice for a 7K dump trailer & factory F-150 hitch #2
Go with the higher limit. That way you will be assured of not yielding your tension rods. I assume your trailer has at least a 5" channel on the tongue to handle the load? This is the WDH that I bought. I looked at the Curt but it was more expensive at the time. Amazon: Camco Eaz-Lift Elite Weight Distributing Hitch Kit, Includes Distribution Hitch, Sway Control and 2-5/16" Hitch Ball - 1,000 lbs Tongue Weight Capacity (48058)
   / weight distribution choice for a 7K dump trailer & factory F-150 hitch #3
I think you would bo ok with either one. On the F150 forums people with newer trucks have problems with trailer sway so the type of hitch seems critical. Your truck is older and the problems are with travel trailers which catch more wind, so I’d say your choice is less critical.
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
LMC LOT NUMBER 142 (A53084)
LMC LOT NUMBER 142...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
