Weight Distributing Hitch on equipment trailer
   / Weight Distributing Hitch on equipment trailer #1
mcfarmall
Kalamazoo, MI
Kubota M5660, Farmall C, JD 260 lawn tractor
I fitted my WDH from the travel trailer over to the Load Trail 8324 14k equipment trailer yesterday and it turned out perfect! I had to buy a set of Hook Up chain hangers that bolt onto the trailer frame. Couldn't use traditional snap up brackets due to a crossmember in the way and tongue tool box. Trailer deck is level when unloaded and the bubble just touches the line (tongue heavy) when the tractor is loaded. Anybody else use WDH on their equipment hauler?
   / Weight Distributing Hitch on equipment trailer #2
If towing heavy, the WDH is a good plan. I bought one for my 14k dump/Dodge 2500.
   / Weight Distributing Hitch on equipment trailer #4
When I’m hauling just the trailer (tongue wt about 200 lbs) I don’t use the WDH. But when I’m hauling the tractor the tongue wt increases above 600 lbs which is limit of my receiver. I always use the WDH when hauling the tractor.
   / Weight Distributing Hitch on equipment trailer #5
We put them on all bumper pull trailers. It's a no brainer.
Sometimes it's hard to do on the 14k ones, and have had to weld the bracket onto the trailer frame because the frame is too big...but it's always worth it.
The ability to steer is kinda a big thing. Plus, no platypusesing on dirt roads.
   / Weight Distributing Hitch on equipment trailer #6
Yep, did the same thing... just purchased the chain hooks and put them on the equipment trailer. Now I use the WDH on both. Makes a BIG difference!
   / Weight Distributing Hitch on equipment trailer #7
I did not, but my truck is heavily built. I can put 5k on my flatbed and not go over the truck’s GVWR. If I was driving a lighter duty truck, a WDH would be used.
These are my rear springs:
   / Weight Distributing Hitch on equipment trailer #8
View attachment 691764View attachment 691765
I have a 14K Equal-i-zer hitch for my 14K equipment trailer.
I also have air bags on my 3/4T tow vehicle.
I MUCH prefer the Equal-i-zer (brand) hitch design over the drop chain style, because the Equal-i-zer design is not subject to turning while backing issues.
Certainly not cheap though.
That 14K Equal-i-zer is now $697.95 on e-trailer.com.
   / Weight Distributing Hitch on equipment trailer #9
Big fan of my WDH and tandem axle trailer brakes on my 7Klbs trailer. Got lucky that I could buy an extra set of trailer frame brackets for the weight distributing hitch that I bought with our camper setup right by the dealer. All my trailers are 2 5/16" balls now, everything interchanges. The only downside is the angle / tongue weight empty on the camper is heavier so the setup is a tad "tail heavy" when i run the 7K equipment trailer empty (using the rear wheels too much which can wear em more). But I don't run it much empty and once she's loaded, it's nice and level. Drives well at speed and brakes straight.
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
JOHN DEERE 850J LGP DOZER (A52472)
JOHN DEERE 850J...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
