Weight distributing hitch bars question
   / Weight distributing hitch bars question #1
hrcarver
NC
jd 6120, 7200, 7700 - ford 2910, 3000, 7610, 7740 - IH 140(2), Super A - kubota m6040
I just got my first weight distributing hitch. Not complicated as it looked.:thumbsup: I got a 1200/12000 pound bar set. It is rated from 600-1200 lb tongue weight, which I think is a real good range that should cover most of my needs.
Here is a link to the one I got Pro Series Trunnion Style Weight Distribution Kit with Shank, 1,200 lbs. TW / 12,000 lbs. GTW Pro Series Weight Distribution 49587
That covers me right? I dont need a 600 or a 800 lb bar do I? I saw several different weights available, but the way I understand it, I can do 500 hanging on the truck.
   / Weight distributing hitch bars question #2
You're good. You can get less lift from it by putting it on a different link on the chain when hooking it up.
Less lift would be a longer chain length, correct?
   / Weight distributing hitch bars question #4
That would be correct, but my WD set recommends that the bars remain parallel with the bottom of the trailer tongue frame.
10-4. I'll keep it close.
40' CONTAINER (A51248)
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A53472)
Neckover GL24-2-7K...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A53472)
2016 RAM 5500...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2011 FORD F-450 (A52472)
2011 FORD F-450...
