Weight bracket on sx3100
   / Weight bracket on sx3100 #1
dslanec
Northern Michigan
CUB/YANMAR SX 3100
Does anyone have the front weight bracket on a sx3100 and if so do you like it? Can you use it and the loader at the same time? I am thinking about adding one for this winter to help with steering. I run a 60" Rear blower most of the time but also have a plow on the loader arms I use sometimes also. I do not want to put chains on the front. Last winter I cut/sipped the front tires and that did help some so I'm thinking if I add weight too that I'll be better off.
   / Weight bracket on sx3100 #4
Ah, like boat shoe sipes!
Are your tires loaded? I use windshield washer fluid, it adds weight without interference.
Yes my rear tires are loaded with beet juice. And in the winter I use chains on the rear so traction is not a issue. Now I am trying to get better steering without chaining the front tires which is why I'm asking about a weight bracket for the front.
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
2003 Evan's Log Trailer, Super Singles (A52384)
2003 Evan's Log...
2025 K3325G UNUSED Double Garage Steel Barn (A53117)
2025 K3325G UNUSED...
2008 New Holland B110 MFWD Loader Backhoe (A53473)
2008 New Holland...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
