Code54
Elite Member
- Joined
- Aug 20, 2005
- Messages
- 4,309
- Location
- Putnam Co. West Virginia
- Tractor
- Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
I finally finished my "carry all/Weight box"
I needed something for my machine for when I use with my grapple as it will often make the rear end real light. I make it about 1400lbs and on the top have all my chain saw stuff. The idea is put it on and when i go to cut trees everything is with me.
It is set up to hold 2 saws, a waterproof box for extra saw chains, fuel, wedges, oil, axes, etc. I also figured I would add a hitch on the rear so I can pull the log splitter. Here is what I came up with.....
The photos show the overall look and some of the construction. The edges are old beams I had laying around and the bottom is very heavy "C" channel (about 6" wide) a friend gave me. I made a solid bottom with it and figured when I drop it down it works as a great "parking" brake - really locks to the ground. I work on a lot of hills and hate just using the regular parking brake as it never seems that strong so I figure this adds another level of safety. All together I have about $200 bucks in everything including a box of welding rods!
Anyway just figured I would see what people thought and share my idea for others builds.
The only negative I found so far is that it is too heavy to move with my BX if needed.....
